Question about Panasonic PT-47WXD63 47 in. Rear Projection Television
Cooling fan in rear does not seem to work, unit may be overheating.
Cooling fan does not seem towork, does it activate at certain temperature.
  • michelleabel May 21, 2009
    What is the part number for the fan or where can I get a new one. Thanks very much for the reply.
  • Panasonic Master
  • 3,866 Answers
Yes the fan activates when the TV gets a certain level of temp now if this never comes on it would need to be replaced with a new fan motor. I would keep a eye on it if you TV seems to be too darn hot because this can cause falures if it does not cool off the unit.. Thanks and please rate.
Posted on May 21, 2009
  • Grand Canyon Tech
    Grand Canyon Tech May 21, 2009
    I do not have the part nuimber the unit would need to be opend to get that information as there are unique part numbers this would be the question I would ask you so I can give you a place to buy it
I have a Goodman CK18-1B ac unit.outside fan will run for awhile then just shut off, compressor stays running like it should
Are you heating or cooling? If cooling is the compressor overheating? Some outdoor fans run only when condenser reaches a certain temperature. If it is in fact a problem, a capacitor is much cheaper than a motor. Replace the cap, if it fixed it, awesome, if not, you compressor will be happy. Honestly does sound like the motor but go cap first. Best wishes!!
Jul 03, 2017 | Goodman Heating & Cooling
My cooling fan just click ON once,then it cuts OFF. I changed the water pump aswell.whats wrong here guys .. bt if i direct it it works
your car will either have a radiator switch / temperature switch either of these controls and activates the fan to work when the cooling system gets to a certain temperature, hope this helps
Oct 10, 2016 | Cars & Trucks
My 97 cutlass supreme is overheating. I've replaced the thermostat and radiator cap, I know my water pump isn't leaking and I don't have a blown head gasket. Started when I pushed 5K RPM.
How do you know it's overheating ? Are you going by the gauge ? Did you check the actual temp. of the engine with scan tool data . or A inferred heat gun at the upper radiator hose near the thermostat housing . Do the cooling fans come on ?Is the cooling system full ? Is there air in the system ?
A coolant temperature switch activates the fan motors. This switch regulates voltage to the cooling fan relay. This switch operates the fan whenever the engine coolant temperature exceeds 110°C (230°F). For location and diagnosis, refer to Electrical Diagnosis. A transducer can also activate the circuit, depending on the A/C compressor head pressure going to the condenser.
The engine cooling fan relays provide the high current required for the cooling fan motors using a low current signal coming from the Powertrain Control Module (PCM). This signal is a function of various inputs
Nov 06, 2015 | Cars & Trucks
My kia blue a headgasket and head was cracket but i replased the head with a brand new head and head gasket put a new water pump on new radiator new heat guage censor new thermostat and still overheat
Are the cooling fans coming on ? What year an model Kia ? Most all newer vehicles have electric cooling fans turned on by the ECM / PCM -engine computer ! The ECT - engine coolant temperature sensor tells the computer how hot the engine is an when it reaches a certain temperature the engine computer supplies a ground to the cooling fan relay that turns on the cooling fans !
Jan 30, 2015 | Kia Cars & Trucks
System fan
Some cpu cooling fan especially on laptop are basically have sensor. There is a certain temperature in order to make the cooling fan activate, when if it's cool then the cooling fan turn off automatically. Same with the air condition thermostat. Good day.....
Other way is to buy a usb cooling pad that fit the size of your laptop. If keeps cool your laptop though and i tried that already and it's effective to cool down the temperature.
Jun 29, 2013 | Compaq Computers & Internet
I have a 1999 oldsmobile intrigue with a 3.5 engine and it is overheating what might be the problem?
It's usually the thermostat, I woud pressure test the cap. It may need to be flushed. Are the fans working? Is there a 50/50 mix of anti-freeze
Sep 11, 2011 | 1999 Oldsmobile Intrigue
I have a 2004 Pontiac Sunfire. When the car is in idle the air blows out hot and the Temperature gage rises and the car over heats. When the car is moving the air blows out ice cold and the temperature...
Sounds like your cooling fans on the radiator are not working. The fans are activated by a thermol switch on the engine or radiator reading the coolant temperature and an A/C switch. When the coolant is too hot the fans should activate cooling the system down. And, when the A/C is on the fans should also activate in order to cool the condensate so the A/C would work.
When you are driving, the movement of the vehicle throught he air is providing enough air flow to keep things cool and functional.
I would check the radiator fan fuse or fuses first. If those are OK I would try to run the fans with 12 volts and a ground that I supply just to see if the fan motor(s) actually run when powered. If the fan don't run when powered then the fans are bad and will need to be replaced. If the fans do run when you power them manually, then something is not allowing the power to activate, like a relay, control unit, or wiring.
It will take a little diagnostics, but it is not too difficult to chase it down.
May 03, 2011 | Pontiac Sunfire Cars & Trucks
Century 170 when useing it .it heats up an kicks a internal circut then cools down an works again till it heats back up. what is the problem an can it be fixed
Hello, I had a similar problem with a mig welder of my own. There is a temperature sensor on the heat sink. This can be in the form of a temperature switch which when the heat limit is reached, it activates a fan which cools down the heat sink. This is how it operates. Now, my problem was I was welding at a high current and it overheated my welder. I fixed this on my welder by replacing the fan with a higher volume one. The issue here is cooling. If you are welding at a high current, then the welder will overheat as the cooling is designed for average use. I am thinking that your temperature switch is not weak but operating as normal. I would suggest therefore increasing the cooling somehow by getting more air moving over the heat sink. An easy try is to have an external fan blowing over and into the welder case. Overheating is the issue here and if you have to weld at the higher currents or welding continuously for long times, then you have to get the unit cooler inside.
joe
Jan 15, 2011 | Welding Tools
Overheating 97 V6 pontiac grand am
1 Inspect Cooling System Mix Coolant level low or flow is restricted. grey_line.gif 2 Inspect Belt Incorrectly routed, adjusted, tensioned, missing, or worn water pump belt(s). grey_line.gif 3 Inspect Oil Pan Gasket - Performance Ruptured, cracked or leaking radiator hose. grey_line.gif 4 Inspect Radiator Cap Worn or damaged radiator cap grey_line.gif 5 Inspect Thermostat Thermostat stuck closed grey_line.gif 6 Inspect Fan Blade Broken, missing, or defective fan blade(s). grey_line.gif 8 Inspect Water Pump Damaged, worn or leaking water pump. grey_line.gif 9 Inspect Intake Manifold Plenum - Perform Leaking water pump gasket. grey_line.gif 10 Inspect Cooling Fan Control Faulty cooling fan control or circuit. grey_line.gif 11 Inspect Cooling Fan Switch - Radiator Faulty radiator cooling fan switch or circuit. grey_line.gif 12 Inspect Engine Temperature Sensor Faulty engine temperature sensor or circuit. grey_line.gif 13 Inspect Temperature Switch Damaged or faulty temperature switch or temperature switch circuit. grey_line.gif 14 Inspect Fan Clutch Worn, loose or faulty fan clutch. grey_line.gif 15 Inspect Ported Vacuum Switch Damaged, leaking, or faulty ported vacuum switch. grey_line.gif 16 Inspect Radiator Obstructed radiator core or radiator cooling fins. grey_line.gif 17 Inspect Head Gasket - Performance Head gasket leaking coolant into cylinders
Dec 01, 2008 | 1997 Pontiac Grand Am
Van chevrolet venture 2000
Fifteen minutes! you have bigger problems than only the fans the fans are controlled by a thermo switch that is heated by the coolant, If you have no coolant the sensor cannot activate But fifteen minutes seems like you may have a headgasket problem and steam cannot heat the coolant sensor.OperationNotesThe electric cooling fan operates when the engine cooling temperature exceeds a certain value. The cooling fan on this engine is controlled by the Powertrain Control Module (PCM) . The PCM turns the cooling fan ON by grounding the coil of the cooling fan relays when certain conditions are met. When the A/C is requested, the cooling fan will also be turned ON.
Power for the cooling fan motors are supplied through Maxifuses(R). The cooling fan relays are energized when current flows from the fuses in the Underhood Accessory Wiring Junction Block, and through the relay coils to ground through the PCM. The Coolant Fan 1 Relay Control Circuit is grounded for low speed fans operation. During low speed fans operation, both fans run at a slow speed. The Coolant Fan 1 Relay Control Circuit is grounded for high speed operation. During high speed fans operation, both fans run at high speed.
IMPORTANT: When certain Diagnostic Trouble Codes (DTCs) are present, the PCM may command the cooling fans to run all the time. Perform the A Powertrain On Board Diagnostic (OBD) System Check prior to diagnosing the engine cooling fans.
For more information regarding the Charging System, refer to Charging System Description , and Charging System Circuit Description in Starting and Charging.
If a problem that involves the low speed cooling fan relay control circuit exists, DTC P0480 Cooling Fan Relay 1 Control Circuit should set. If the problem affects the high speed cooling fan relay control circuit, DTC P0481 Cooling Fan Relay 2 Control Circuit should set. A problem with the ECT sensor should set DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage, DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage, DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage, DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage. Any of these DTCs will affect cooling fan operation and should be diagnosed before using the Electric Cooling Fan Diagnosis.
For more information regarding the Cooling System refer to Engine Cooling Fan Description - Electric, and Cooling System Description in Cooling System.
Here is the electrical schematic and how it all is suppose to work,
If you need any further help please contact me Thank you,Randy If you find this information helpful please give me a good rating
www.aceautomotive1.com
Aug 16, 2008 | 2000 Chevrolet Venture
Panasonic PT-47WXD63 47 in. Rear Projection Television Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
