Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Error code 5d
Don't allow door lock and don't reset
I have a whirlpool duet front loader I have had error code 5d appear and the machine has stopped what should I do as the door is locked and I can't remove my clothes
The 5D really stands for SD (SuDs) and is an oversudsing code. The machine shuts off. Try unplugging the unit for about 30 minutes. Then plug it back in and set control to drain. This should release the door.
This alarm may also occur if the drain time takes very long time. Try washing without soap to clean the machine. Use HE soap and use the correct amount. Don't think more is better.
Sep 04, 2016 | Whirlpool Washing Machines
F9 still appears after unplunging and replug
Hi Don, this is Z. Thank you for your post!
If you are receiving error code F9, it typically indicates that the maximum oven door unlock time has exceeded. If resetting the power did not clear the error code, it would be advisable to contact an experienced appliance repair tech to assist further since your range may possibly have a communication error with the EOC (Electronic Oven Control), lock motor assembly, door light switch or door latch assembly. Hope this helps!
Jul 19, 2014 | Frigidaire Ovens
Don't have code for door locks
look where your jack is and using a flashlight shine it up towards the wheelwell and you will see a set of numbers thats your keyles entry code for your explorer
Jan 19, 2013 | 2001 Ford Explorer Sport
I need to reset my phone, but im locked out. How do I reset it if it's locked and I don't know the code?
What is your mobile and model ?
If you forgot the security code you have to reset you mobile. Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means just visit here Simpleunlocking.com for the master reset code service and get the reset code........
May 14, 2012 | Cell Phones
Phone on then went code.i don,t know code
If you don't know the Lock Code means You can master reset your Nokia 5130 Phone,You can get the master reset code from here Unlocking4u
and reset the Phone...
Jul 17, 2011 | Nokia 5130 Cellular Phone
The lock light is not coming on so the wash cycle is not starting
The machine cannot lock the door. Sometimes the result of a slightly sticking door interlock mechanism. Open the door and close it hard and firmly (slam it a bit, but don't get silly about it!). A good test to see if this is the problem is to attempt a program with the door swinging open. If the symptoms (flashing key) are the same, then the issue is almost certainly narrowed down to that door lock mechanism.
If this fails, unplug the machine from the main power source and leave it for 20 minutes to allow it to reset its self, then try again.
Jul 11, 2011 | Candy Washing Machines
I have a EA23 security safe i bought at a yard sale how do i reset the password ? where do i get operating manual
I finally get to provide a solution for something!!!
Open door with the key, press the reset button hiding on the hinge side of the door mechanism, you will hear a beep. You don't have to have the key in or out. Enter your new code, and press A. Then lock it and test your code.
Robert
Jun 13, 2011 | Sentry Security Safe with Electronic Lock...
DISPLAY CODE F5EI
we got the same thing. do you lock the door? if we don't lock the door we don't see that problem.
Apr 11, 2010 | Kitchen Ranges
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
