Question about Samsung Microline ML2851ND Laser Printer
My Samsung ML2851MD printer is leaving black spots on the left side of the page
Printer leaving black spots on left side of page
  • 1003 Answers
SOURCE: Black lines across page
are black lines appearing on paper after printing from computer or when a fax is sent or recieved or both?
Posted on Jan 15, 2008
SOURCE: Samsung CLP-300 Printer
This is a manufacturing defect. Call Samsung at 1-866-726-4249 and explain the problem. They will replace your imaging unit free although you will most likely need to provide a credit card for them to hold until they receive the defective unit back from you.
Posted on Oct 28, 2008
SOURCE: Samsung CLX-2160, keep getting faded
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
Posted on Jun 30, 2009
  • 7 Answers
SOURCE: My CLP-350 Samsung printer only prints black ink
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Posted on Feb 10, 2010
  • 3 Answers
SOURCE: samsung clp-315 printer stops printing after half page
i have samsung colour printer. half page printing then stop the printer. after turn on the printer the balance page automatic take out
Posted on Jul 21, 2010
Black spots at the back page
Hi George,
Sounds like you are on the right track.
The spots on the paper you describe on the back of the paper appear to be toner, and because they are on the back of the paper and you can rub them off, appears to be after the fuser.
To clean the printer, a vacuum cleaner will do a partial clean. You need to clean all the paper feed rollers.
Start by wiping the inside of the printer area with a soft, lint-free cloth to remove any dust, paper particles or spilled toner.
Then use a damp soft, lint-free cloth with clean water. Hold the cloth against each roller while rotating the roller. Keep cleaning the cloth. Do this for each roller inside the printer.
Read more: http://www.ehow.com/how_6913741_clean-roller-blades-samsung-clp_300.html#ixzz2sGMAltnZ
Feb 03, 2014 | Samsung CLP 315 Laser Printer
I have a samsung clx-3160 fn printer, approx 1.5 yrs old. Has worked well, however now the right side of each page is slightly faded compared to the left side. I have cleaned out what I can and replaced...
I'm not sure if it is a similar problem but I have a CLX-3170FN and it has started to run a strange line down the page, and part of the page was smudged. I cleaned it all out and looked at the drum etc and it was all fine. Then I spotted there is a plastic belt that must run like a conveyor belt behind the drum and there is a split running along it - Found out it is called the transfer belt. It was difficult to see which I why I am suggesting it to you. Now I just have to find how I can replace mine. :)
Feb 22, 2010 | Samsung CLX-3160 All-In-One Laser Printer
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Jan 09, 2010 | Samsung CLP-350N Laser Printer
Spots along left side of page. On every printed page there are black spots along left side.
something on the fuser... is it the same distance from each spot every time?... then something is on the fuser roller, so it gets fused every time it rolls over that spot. thats my guess
Sep 08, 2009 | Samsung Office Equipment & Supplies
STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Apr 16, 2009 | HP LaserJet 1020 Printer
I have a Samsung SCX-4725FN & it is leaving black marks 2 inches apart on the left hand side of anything I print.
Ddcorbin.... lift the cover... on the left side of the plate is a long black glass strip. wipe that glass strip with a soft towel. i used windex. the black mark should be go away.
Apr 11, 2009 | Samsung SCX-4725FN All-In-One Laser...
Samsung ML-2010 Mono Laser Printer leaves unwanted marks on page.
if older printer or well used printer (All laser printers if they have print quality issues - it is mostly either the toner or the fuser). the only way to tell is get (borrow) a toner and see if problem is the same or remove the fuser (the hot thing in the printer) and see if the "ironing" unit or fuser rollers are dirty or worn out or scratched
Mar 01, 2009 | Office Equipment & Supplies
Black spots of the left side of the print
If you know how to remove your drum cartridge, take it out and check if you don't see your black spot on your drum....If so, replace your drum cartridge.
You may have a bad fuser to....
let me know !
Apr 01, 2008 | Samsung Laser Multifunction Printer Toner...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Samsung Microline ML2851ND Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
