Question about Baumatic BTWM4 Front Load Washer
Baumatic BWD12 Hi,My Baumatic BDW12 waher dryer has a torn door seal. Do you think I can chnage it myself? Do you know where I can get a service manual?ThanksPSGlink to door seal spare: http://www.partmaster.co.uk/cgi-bin/product.pl?PID=1086055§ion=111076&brand=Baumatic&model=BWD12&path=66991,110824:79156,111076
  • partho Oct 19, 2007
    Wow, that was quick!
    I'll download it and chck it out.
    May bother you for some help incase I am stuck.
    Thanks thanks
    Partho
    Hi eagle,
    The Manual does not tell you about repairing the door seal.
    Futhurmore, it is for a Hotpoint washing machine and not a Baumatic (the model no is the same for some reason)
    Please help!
  • 4,889 Answers
Yes you can do it yourself using the manual which can be found at the link below...
http://www.laundrymanuals.com/manuals/mfg/hotpoint/bwm12_bwd12.html
You will need to register for free to download it.
If you couldnt do it for some reason just let me know and i will guide you..
Happy fixing!
Posted on Oct 19, 2007
  • eagle338
    eagle338 Oct 19, 2007
    The way that I do it is to remove the top panel (3 screws at rear).
    Look down at front of the machine, and there is the door latch
    assembly. Three screws hold it in place (Torx). Remove the screws, and
    remove the 3 wiring connectors. Assembly is reverse. I hope this helps!
  • eagle338
    let me know if it worked..
SOURCE:
LG HE Waher model WM2010c, rubber door seal slid and distorted the seal edge, on a spin cycle with a towel in it, how do I fix this?
If seal/boot is not torn, then remove front spring/wire clamp, reposition the seal/boot, reinstall the spring/wire clamp. Check out repair videos at appliancepartspros.com or repairclinic.com.
Feb 01, 2017 | LG Washing Machines
Howh do i replace the gasket pad
Nancy,Could not find instruction for seal removal on your particular model, did post links to models, hoping they will be close/same as yours. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Door Seal part WP3405245 How To Replace
How To Replace Torn Or Worn Out Dryer Door Seal
Dryer Door Seal part 33002094 How To Replace
Jul 10, 2016 | Maytag MDE2400AYW 24 High-Efficiency...
How to replace the door rubber seal and part number
Here is the door seal to order.
Below is a video to show you how to replace the boot. The model may be a little different but the process is the same.
Feb 17, 2013 | Samsung SM-WF338AAW - SERVICE MANUAL
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Jun 07, 2009 | Dryers
Baumatic megawdss leaks in front when wash cycle starts. How do I fix this?
The front door seal is bad,check to see if there is anything jammed up inside that seal,money,ex,ex,lint
May 07, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Black carbon/soot on the door and lint filter of my dryer
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Torn clothes
Rollers
Rear seal
Front glides
Front seal
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Mar 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Something went snap!
same thing happened to me. The door spring broke on hte right side. Got the baumatic people to come out to fix it at a fixed cost of £79. I think the spring part is only £3.
May 14, 2007 | Baumatic 23 in. BDW5 Built-in Dishwasher
Baumatic BTWM4 Front Load Washer Logo
594 people viewed this question
Top Baumatic Washing Machines Experts
jimorris77
TriciaGirl
Level 1 Expert
Marvin
Marvin
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
