Question about NEC DT330 - - Phone
How to turn off blinking light on extension?
This extension button light is blinking even though there is no message. How do I turn it off?
My message button is flashing on my Toshiba DKT2020SD phone, telling me i have a message. When i press the Msg button, it it calls another phone extention in another office and i hear that it is on speaker...
This is what I wrote up for our inhouse manual on telephone administration for this phone:
Problem: An employee pushes the Message button to receive a message but it calls someone else's desk. This is caused by whichever extension the phone forwards to when pushing the Message light. For example: if the person at 333 pushes their blinking message light and it forwards to 316 that means that the person at 316 most likely tried to call 333, got a busy signal and accidentally pushed the Message button before hanging up thus setting 333 to call forward to their extension when they got off the phone.
All phones on our system should have this feature turned off, but if it happens this is the two step process to resolve the issue:
Solution: First, push the Message button to figure out which extension it is forwarding to. Take note of the extension and hang up. With the hand set NOT picked up, dial #409 and Release. You may have to do this multiple times to clear the call forwarding because it needs to be done for each incidence that the person accidentally set up call forward. Finally, in the management software go to Station > Station Assignments. Select the extension # that the Message button was forwarding to (the one you noted above). Under the Basic tab at #41 Active Message Waiting select Disable. Select Submit.
Aug 29, 2011 | Toshiba DKT2010SD Phone
Uniden message light blinking even though all messages have been deleted
Hi billkratzenb,
Try turning the device off for 5 mins, and turn it back on.
if the light still blinks even though there are no messages, go through the device settings and restore everything to Factory Default.
I hope this has helped, Good Luck!
Mar 15, 2011 | Uniden TRU8866 Cordless Phone
My message light is flashing even though I've cleared all messages
There might be another voicemail box associated with your extension. Hang-up the receiver and press the voicemail button. It should tell you where the voicemail is sitting. If you do not know the passcode for that voicemail, have your system admin take a look at it.
Sep 13, 2010 | Mitel 5330 IP Phone
My message button automatically calls another extension How do I get it back to answer my voicemail
the reason the message button is calling another extension is because that extension turned your message light on. to turn off the message light either press the msg button and have the extension answer the call or press intercom #409. You'll have to that for each message recieved til the light goes out.
Oct 13, 2009 | Toshiba DKT-2020-SD telephone
Can't turn my HP D5460 off
To turn off the HP D5460 Photosmart is by pressing the ON button located on the product. Wait until the on light turns off that mean it's off.
Apr 12, 2009 | HP Photosmart D5460 InkJet Printer
Strata 3010 msg light won't turn off
To manually turn off the message waiting light press your extension button then press #409. Do this step for each message received.
Mar 25, 2009 | Toshiba DKT 3010 Corded Phone
Message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
  1. Hit that button to show *Options List / # Setup list
  2. Press * to go into options.
  3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
  4. Then hit 3 again to clear the message waiting
This should resolve the blinking light.
Nov 11, 2008 | Astra Meridian 9417 Corded Phone
Philips CD445 phone.How do i turn off the red blinking lights
Good luck. If you follow all of the above instructions and the red light keeps blinking, that's just the way it is. And that's according to the Philips tech support team. Especially if it's in relation to voice mail icon. The phone appears to think you have a voice mail message even if you've checked it and deleted them all or have no voice mail service whatsoever. So you may be stuck with the blinking red light forever.
Jul 04, 2008 | Lands Phones
The message light does not blink when there is a message.
No it is not. that is for dialing home, pager or whatever. the voice mail system needs to have message notification on for your extension and the code it uses. This is done by your tech. If the phone will get a message ligt when moved to an extension that it is known working, on then it is NOT the phone. It is either the phone system or the voice mail system programming.
Let me know,
Thanks.
Bob
Oct 15, 2007 | Toshiba DKT-2010 Corded Phone
NEC DT330 - - Phone Logo
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
