Question about Circo Toys
Broken piece Pink plastic piece broke on playpen that holds bars together ...can I get a new one sent to me
SOURCE: oasis elite washer lid locking mechanism broken
go to repairclinic.com to find the part. Have the make and model ready, and you have a good chance of finding the part there.
Posted on Mar 02, 2008
SOURCE: Cosco Buckle Broken
I need a new plastic buckle for my car seat straps
Posted on Sep 30, 2008
SOURCE: sentry s3877 battery compartment broke
I had the same problem with my Sentry S3877. I found the exact 4-battery replacement (with snap attachment on top!) at an online electronics.retailer, but had to purchase a lot of three. I don't need the other two, so I'll sell them for just $6 each to the first two folks to contact me mark@irregardless.net.
Oh, by the way, once the batteries went dead, you lost your combination! When you pop the new battery compartment in, the factory default combination will be in effect. That default combination is in your user's manual. I'm currently searching frantically for mine! Gee, how could I have misplaced it ... I just had it in my hands when I purchased the safe 10 years ago !!!
Anyone know the default combo for the S3877?
---- Mark
Posted on Nov 14, 2008
  • 137 Answers
SOURCE: HP 7410xi small plastic piece in print cartridge carrier broken
If the spring did not damage the carriage flex I would suggest just using some epoxy to hold the spring properly in place. If the spring did damage the flex (as shown in this picture) then you might contact HP and enquire about an extended warranty for this issue. In the US call HP at 1-800-HPINVENt.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Mar 02, 2009
cjackHD
  • 71 Answers
SOURCE: The small piece of plastic (with BOSE on it)that
You can have Bose replace the headset for you (new w/ 1-year warranty), but if it's past it's current 1-year it will cost you $60.Unfortunately Bose doesn't supply parts for that headset, but you could try using plastic adhesive as a low-tech fix. First Google search result for plastic adhesive:http://solutions.3m.com/wps/portal/3M/en_US/Windows/Doors/Product-Information/Products/Adhesives/Plastic-Adhesive/ .
Posted on Jun 12, 2009
Piece of lid broke off
Sand the area on bottom of piece along with areas surrounding the broken piece. Get another small piece of plastic that is large enough to cover the broken piece and adjacent areas and apply the glue to that using a good epoxy for adhesion. Let it set up and it will hold - trust me.
Sep 27, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
How do I fold up the playpen
It's a struggle!
Pull up on the handle in the centre of the floor till it is as high as it can go.
On each of the sides there is a plastic piece in the middle. If you feel around them you can find a little button sticking out (it's on the side facing out of the playpen). Push that little button and push down on the middle of the top bar and it should collapse. There are 4 sides to the playpen - and 4 little buttons.
Nov 28, 2012 | Kids II Bright Starts Ingenuity Sleepeasy...
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
The plastic piece that holds the rod from cylinder to the paddle is broken. How can I fix that?
For a temp. fix, grab some wire and wrap it around each rod, then insert into the hole (were the plastic piece broke) and wrap those two together, YOU NEED to repair it correctly, go to dealer and they have pictures that can locate the plastic bushing.
Feb 14, 2011 | Pontiac Grand Am Cars & Trucks
I broke the green plastic piece off that holds the ink in my sharp ux b700 fax machine where do i get a replacement
Take your ink out of the fax and clean the broken part with alcohol and then just super glue the piece in, it does not have to hold any weight, so you shouldn't have any problem with it if it just holds the ink. Super Glue and plastic work great together.
Mar 19, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
The latch that opens the Trunk (Hatchback - as it is a minivan) is broken. I cannot open the back...
If you still have the broken piece, you can try to use that to try to open the back. Otherwise, you have to open it from the inside.
I changes mine in 2007 so if memory serves me, I had to remove the back panel and pull on the cable to open the door.
Now to see and pull on the cable, and replace the latch, you have to take off the inside liner/panel to get to the latch to replace it. This took about 2 careful hours to replace.
The trick is to get the two side pieces off.
These two plastic pieces are next to the window on the left and right sides. Each piece is about 3 inches wide and 18 inches long. Using a strong grip, or a pry bar or large screwdriver, take off both pieces. There are three clip areas that holds each piece in.
If you are using a tool, be careful to protect the area by wrapping a towel on the screwdriver/tool.
After that the bottom liner piece pulls away and you can see the latch.
There are two screws/bolts that holds the latch.
The two pieces snaps back in pretty easily.
You probably broke the plastic piece shaped like a J.
You can try to glue the pieces back, but note that the piece broke due to age. I changed the whole assembly - good for another 7 yrs. I could not find just the plastic piece.
Aug 29, 2009 | 1999 Toyota Sienna
My 1999 Toyota Sienna has a broken rear latch
I answered this for someone else -
I changed mine in 2007 so if memory serves me, I had to remove the back panel and pull on the cable to open the door.
Apr 13, 2009 | 1999 Toyota Sienna
Space bar sticking on Saitek lighted keyboard
For me, I popped of the space bar, cleaned the junk underneath and fidgeted with the plastic push-button and all was better. Thanks for the suggestion!
Feb 21, 2008 | Saitek Eclipse II
Toys Logo
Top Circo Toys Experts
ray gallant
Are you a Circo Toy Expert? Answer questions, earn points and help others
