Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Parametric Graphing of Inverse Functions
When I attempt to graph a function and it's inverse in parametric mode
Ex:
X1: Tsquared + T
Y1: T
X2: T
Y2: Tsquared + T
The calc only graphs both equations in Quadrant I.  They both should be parabolas
    Sergeant:
  • Texas Instru... Expert
  • 265 Answers
See carefully captured images below
Parametric Graphing of Inverse Functions - parametric-graphing-inverse-functions-vmeepxeodbkuphgqq1hkgvwl-1-0.png
Parametric Graphing of Inverse Functions - parametric-graphing-inverse-functions-vmeepxeodbkuphgqq1hkgvwl-1-6.pngg-inverse-functions-vmeepxeodbkuphgqq1hkgvwl-1-6.png" alt="parametric-graphing-inverse-functions-vmeepxeodbkuphgqq1hkgvwl-1-6.png" class="h_mi" />
Posted on Mar 26, 2016
  • 58 Answers
If your looking to make a parabola out of it add
X3:T²+T
Y3:-T
X4:-T
Y4:T²+T
Those functions are not parabolas. since T² cannot be negative since negative times negative = positive. (unless it's an imaginary number, but thats a different story)
Posted on Feb 08, 2008
How do i graph a circle in parametric mode?
The simplest way is
X1=cos(T)
Y1=sin(T)
Set angle unit to radians,
Set the Zoom window to SQR (square), otherwise your circle will look like an ellipse.
Sep 04, 2014 | Casio FX9750GII Graphic Calculator
"Undefined" as answer to an inverse sine calculation
I suspect that you are confusing things a bit.
The inverse sine, called the arcsine is a function defined in the closed interval [-1,1]. And so is the inverse cosine. Any value outside this interval will give you a non-real result (meaning a complex one).
There are no limitations on the domain of definition of the inverse hyperbolic sine or sinh^-1
If your input value is allowed to be complex, the arcsine function gives a complex value. See the screen capture
Mar 17, 2014 | Texas Instruments TI 89 Titanium Graphing...
I can not graph a parametric equation useing radians. I am using a TI-nsipre with out any updates since purchase not a CAS or CX one.
In parametric functions, the variables x and y are both functions of an independent variable, called t, and that usually represents the time. The default variable in parametric functions must be called t. You can enter the limits you want. However if you type in 2 Pi it will be converted on the entry line to 6.28. The default tstep is 0.13 which is about pi/24. I fail to see what the commotion is about.
In this representation of the witch of Agnesi, the variable t is between 0 and 4Pi, and the step tstep is 0.13, a little less that pi/24
Reset your calculator and restart
Mar 14, 2014 | Texas Instruments TI-Nspire Graphing...
My casio fx-9750 is stuck on T when I use the x, theta, T button. How do I get it back to x?
T is the default (independent) variable name in parametric function graphing. Change the graphing mode to function y=.
Jun 13, 2012 | Casio FX-9750GPlus Calculator
My 'X=" isn't showing up above the "Y="
When you push the button [Y=] to open the function editor you will see Y1=,Y2= etc. That is the default behavior. By default the graph type is FUNCTION (y=f((x). However there are other graph types, for instance PARAM, POLAR, and SEQUENCE.
For Parametric graphs, you need two functions x as a function of t and y as a function of t. In this case, when you open the function editor, you will see pairs of functions x1(t), y1(t), x2(t), y2(t), etc. Both x and y functions of the pair must be supplied.
So if your x= function is not showing, then you must open the MODE screen, and scroll down to reach the 4th line that says FUNC, PAR, POL, SEQ. Highlight PAR and press ENTER. You do that only if you want to graph parametric functions.
Nov 04, 2011 | Texas Instruments TI-84 Plus Silver...
When i am graphing and I enter- Y1=Sin(theta) it does not graph it and says syntax error
When drawing function graphs of type Y1=, the name of the independent variable should be X
For polar graphs r=.., the independent variable is theta, while for parametric graphs it is T
To enter the default independent variable, press the key marked [X,Theta, T] . It will type in the correct name.
Sep 18, 2011 | Casio FX-9750GPlus Calculator
I am using a casio graphing calculator and I am trying to graph a parametric function. I put the mode on Param and I inserted xt and yt and i press draw. It draw but then stops and gives me an arugment...
The argument error must have something to do with the parametric functions you are drawing. I do not think anybody would know where to look unless you give us the functions.
As to the range of the T-variable, you can set it by pressing [SHIFT][F3] to open the (V-Window) configuration screen. It starts showing Xmin, Xmax. etc. To get to the T range, use down arrow (about 7 times).
Dec 06, 2010 | Casio FX-9750GPlus Calculator
I need to generate a graph (graphing trignometric equation in parametric form). The equations are, x=3cos(teta) y=2sin(2teta) We are getting error while generating
At first, you have to use t symbol for parametric functions when you operating with TI 89 Titanium. In your case you must input your relations as x1=3cos(t) and y1=2sin(2t). Then graphing it. See captured image
Sep 21, 2010 | Texas Instruments TI-89 Calculator
Graphing inverse equations
In parametric mode you are not drawing one function, but two functions X1(T) and Y1(T). If you use the DrawInv( command either on X1(T) or Y1(T) you get a syntax error.
However if you are drawing functions in Funct mode you can draw the inverse of the function that has been graphed.
Here is how you do it.
[2nd][Draw][8: DrawInv] [ENTER]
The command appears on the home screen, and you need to tell it the function it will act on. To do so press
[VARS] --> Y-Vars [1:Function]
and select the function you want, say Y1, if Y1 has already been defined.
DrawInv Y1 [ENTER]
Both Y1 and its inverse will be drawn.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-84 Plus Silver...
How to graph an equation on a t1-83?
how to fix window to graph Pythagorean property
Sep 01, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
631 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
