Question about Samsun UN32EH4000 32" 720p LED-LCD TV - 16:9 - HDTV
UN32EH4000 change aspect ratio
How do I change the aspect ration on this TV
I moved my TV this afternoon and now there is a dark border at the top and bottom. How do I fix that
Widescreen letterbox and black bars How to wrangle TV aspect ratios
It would be helpful to post brand and model of equipment.
Possibly the aspect ration has been changed. Some remotes have buttons which alter this (sometimes a format button, sometimes a p button.)
Jun 10, 2017 | Televison & Video
Why do i have a large line at the top and bottom of the tv
This is caused by aspect ratio. To change you have to go into set up and alter the ratio shown as 9:16 , not sure what ratio you will have . Note som tv's have an auto chaning aspect ration for films ect.
May 14, 2017 | Televison & Video
I'm trying to change aspect ratio from 16-9 to 4-3 on dxc-d30ws
get the onscreen menu up and alter aspect ratio settings
as the ratios are changed you will see the screen change to suit the new ration
it it is a late led type you may have to select the pixel sizes to get the screen size to change
Jan 13, 2017 | Televison & Video
The picture is in the middle of the screen on my sanyo tv. Is the tv playing out or can I fix it?
could be or the aspect ratio has changed
get the on screen menu up and find the scree aspect ration using the volume buttons adjust till the picture is full screen with the figures the right size( not tall and skinny or short and fat)-- ok then exit
Jun 09, 2016 | Sanyo Televison & Video
Daewoo DTQ-19TV1fc aspect ratio changed to letterbox. How do I restore it to full screen?
get the on screen menu on the screen
scroll around till you see aspect ratio and click on that use the buttons to change ( you will see the changes on the screen)
click ok and exit when satisfied
Fir aspect ration to change there can be a few reasons
some tv stations produce movies in the wrong ratio and it shows up for the movie as black edges or tall figures or fat figures ( change channel to verify)
or there can be a fault occurring in the board of the set that will not hold preset aspect ratios
Oct 26, 2015 | Daewoo Televison & Video
HD programs work fine, however, the standard pictures are distorted. I had this once before and someone fixed it but not sure how.
You probably need to to turn your aspect ration on the TV down. Newer HD screens use a 16:9 aspect ratio for HD content which is a wide screen format. Standard definition TVs and programs use a 4:3 aspect ratio. Most flat screen TVs have an option to display in 4:3. This option is most often found in Menu/Setting>Video Options>Aspect Ratio. For standard definition programming you want 4:3, for HD you want 16:9.
May 05, 2011 | Televison & Video
People look short and fat
You are trying to display standard definition TV 4:3 ASPECT RATIO to fill up the 16:9 screen and that is what you will get. You need to use the 'APSECT', 'P.MODE', or 'WIDE' button to set correct aspect ration to match the video source aspect ratio. Please see you owner manual for more details.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 07, 2010 | Vizio Televison & Video
Picture is to tall. it cuts off the top of the heads
It sounds like you have the image on the perspective. If you tv is 4:3 aspect ration the video source (cable box, dvd ) must be set for a 4:3. If you have a 16:9 ratio (widescreen) the soutrce should be set to 16:9..................Nevermind, Just looked it up you this TV is 4:3.
Your TV remote will have a button to toggle/change the aspect ratios of the TV. Button could be called picture/aspect/image etc. If you have an HD cable box you need to go into the video setting and chnage the aspect ratio to match the 4:3 tv.
If you need more help, please respond with more deatils.
Jan 19, 2009 | Sanyo DS32830H 32" TV
Aspect Ration for Panasonic TV
Should be an option under the video menu for format
Jan 16, 2008 | Televison & Video
Samsun UN32EH4000 32" 720p LED-LCD TV - 16:9 - HDTV Logo
12 people viewed this question
Top Samsun Televison & Video Experts
Are you a Samsun Televison and Video Expert? Answer questions, earn points and help others
