Question about Exercise & Fitness
Tunturi manuals How do I adjust the shocks?
Looking for a manual for a tunturi uni cam Pro f530- can anyone help?
If you can't find one on this Tunturi web site, I don't think you find one.
Manuals Tunturi New Fitness
Dec 16, 2014 | Tunturi Exercise & Fitness
Tunturi C35 clunks
Download: www.manualslib.com/manual/184017/Tunturi-C35 for how to get the owner's manual. If your cross trainer is anything like mine there are joints all over the place to be adjusted and tightened and lubricated all the time. THe clunking can be from any or all of them....check each joint for excessive play and adjust to a reasonable tension.
Jan 02, 2013 | Exercise & Fitness
How do I fix the pulley sytem on Tunturi R60 Rower
go to manualfox.com - they have listed many tunturi manuals as "found"
Nov 21, 2012 | Tunturi R60 Rower
Regarding my Tunturi j800 stuck in the incline position: thanks Tim for the response. I'd love to manually lower it, but there is no flat head screw on any metal-encased fan. The only fan belon
Dear Sir:You must RUN the software calibration for easy diagnose, troubleshooting, and fix it. After that you need adjust the speed sensor, see the diagram attached, clean, and tight the connector very well. Then you can lube the gear and shaft from elevation motor b) adjust the potentiometer c) test the elevation motor. But first RUN s. callibration.
May 03, 2012 | Tunturi Exercise & Fitness
My Tunturi j800 is stuck in the incline position. Other than that, it works great! How can I get it down? The screen reads that it's at 0% incline.
RUN THE SOFTWARE CALIBRATION FOR DIAGNOSE, TROUBLESHOOTING AND FIX IT.
2) you can lube the gear, shaft+ adjust the potentiometer+see the relais contact are clean it.
sincerely. God bless you
May 02, 2012 | Tunturi Exercise & Fitness
Need a manual for tunturi r60 rower
No problem, all Tunturi equipment manuals are available here: http://www.tunturi.com/service/manuals/
Mar 08, 2012 | Tunturi R60 Rower
Tunturi j9 err 10
Dear Sir:
This error is indicating the elevation motor is overspeed.
Adjust the sensor speed see the diagram , and then Run the Software calibration for easy diagnose and troubleshooting.
See my personal TIPS, for diagnose and troubleshooting.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 07, 2012 | Tunturi Exercise & Fitness
I am looking for a manual for a Tunturi C20 Cross trainer
http://tunturi.crealisten.com/js/admin/kfm/get.php?id=292
May 15, 2010 | Exercise & Fitness
User manual and parts for tunturi ergometer w
I need a friction pad cable for my tunturi erometer w excersise bike. Can you help please.
Thanks
Dec 27, 2009 | Tunturi Cycling
Exercise & Fitness Logo
62 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
