Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
On all Channels except the ABC and 9, the message comes up ' failed to receive broadcast E202. Why?
  • 8 Answers
SOURCE: Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
Posted on May 22, 2009
SOURCE: 37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Posted on Aug 23, 2009
micromatikal
  • 2777 Answers
SOURCE: Failed to receive broadcast E202 Sharp
What do you mean exactly when you say "failed to receive broadcast"? Does it not get a signal of any sort? What about from DVDs, do you have a DVD player attached, does that work? Did it used to work just fine with regular TV signal?
Thanks, let me know more and I can definitely help!
Tim
Posted on Sep 29, 2010
  • 25 Answers
SOURCE: I dont want to use
you need a antenna with digital capabilities.you can generally find them cheap and make sure tv is set on antenna instead of cable.
Posted on Jun 28, 2011
  • 11800 Answers
SOURCE: Failed to received broadcast E202. what's
It means that the tv doesn't gets the correct signal from the cable or the antenna - check them.
Posted on Oct 07, 2011
Sharp aquos instructions
That means the channel is active but but there is a problem with the delivery by the broadcaster, not a defective TV.
Dec 28, 2013 | Televison & Video
Comcast tv failed receive broadcast e202
Check the input cable to the TIVO is is firmly connected at both ends?
Dec 16, 2013 | Tivo Televison & Video
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
Failed to received broadcast E202. what's wrong?
Oct 07, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I dont want to use cable. I plugged a rabbit antenna and i get the message "Failed to receive broadcast (E202)
Jun 28, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Jerky video on antenna feed of ABC network programming
You didn't say so but I believe the TV you're using that having the problem is a TV that uses motion compensating frame interpolating technology... a common feature with 120hz and 240hz LCD TVs. I have one of these types of TVs and I have this issue with ABC as well. ABC has begun dropping video frames from some of their primetime shows (the ones that start at the 8e/7c time slot seem most effected) to speed up the broadcast to a point where they can get an extra commercial in. On normal TVs, including the older 60hz LCDs, this is not really noticeable. However, for the motion compensating frame interpolating technology, the TV's video processor must sync up with the 'telecine' processing (conversion from the originally filmed 24fps to broadcast 60fps) so that it can eliminate the copied frames that the telecine processing produces before it can create the interpolated frames between the original frames. When the TV's processor hits a missing frame, it loses sync and has to rejoin and causes the jerky motion you're seeing.
For a solution, you can turn off the motion compensating frame interpolation tech on your TV. Each manufacturer calls it something different but the name will have something to do with smoothing out motion like 'Smooth Motion'. In this case, you need it off for the motion to be it's smoothest (not the case with most TV though).
For a better solution, send a complaint to ABC and your local ABC affiliate.
Dec 12, 2008 | Proscan 47LB45H 47 in. LCD TV
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
