Question about Acme 6001 Juice Extractor
How to open it? - Acme 6001 Juice Extractor
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Jul 23, 2012 | Acme 5001 Supreme Juicerator Juice...
How do I open it to clean up
Go to this website: http://www.powerjuicer.com/power-juicer-manuals.php
Select your model to open the Operating Manual which contains illustrated assembly and disassembly instructions.
You will also find a number of useful links on the right hand menu as well as a selection of How To videos that may be helpful.
Mar 07, 2011 | Jack Lalanne Power Juicer (Stainless...
I m unable to open the the juicer as need i clean it inside.
Assuming you are dropping down the metal arm, removing the plunger and the rear pulp collector: everything unscrews from there. Hope you did this immediately following the juicing as it gets sticky and can be hard to open if you waited until it dried. When you get to the screen, it opens with a red tool they provide to unscrew it. Hope this helps.
Feb 24, 2011 | Jack Lalanne Power Juicer 250 Watts
Loud "pop" noise as if
The reset button is actually a circuit breaker in miniature but there may be a thermal fuse to protect against fire in case of failure of the circuit breaker.
If you are game, open the housing again and look for a device you don't recognize that is in series (in line) with a wire; it may be in an insulating sleeve and not immediately visible, appearing only as a thickening of the wire. This could be a thermal fuse.
They are not supposed to open under load but only when the temperature exceeds a limit and these do not reset. Unfortunately, these are now all coming from China and are not very reliable so may open even when the design temperature is not exceeded.
If concealed, you would need a simple multimeter to determine if it had 'opened' by checking for the continuity of the wire stretch.
Blenders in general are 'universal' motors which can use AC or DC and this type employs carbon brushes which do abrade with time and when they have become too short, they can become intermittent and cause such a popping sound too. Brushes are replaceable so you might check Waring's website to see if they offer a fixed-price replacement or brushes as replacement parts.
I would be prone to see the Waring restored since most replacement blenders are from China and have often more than just one problem even when new. One given to us as a present smoked while crushing ice so we retrieved our old Oster from its stash and tossed the oriental wonder.
Jan 09, 2011 | Waring Juicers
How do you open the blade on the jui3567cer
open the blade? you mean get it out for cleaning? just pop it out by putting a knife or back of a spoon under it and gently pry it up in a few places. works like a charm, been doing it for 5 yrs
Jan 03, 2011 | Jack Lalanne Power Juicer 250 Watts
How to remove strainer/grater from vitamin bar juicer
I am assuming your juicer is the same as mine. The JC-6 White with "Vitamin Bar" and a carrot on the front.
There is most likely a tool that you insert in the back slot, but since I don't know of one, I had to get creative.
First unplug the juicer and undo the side locks, remove the clear cap. Look in the back, there is a 2-inch wide slot where you can see the motor and locking mechanism.
Take a butter knife and hold the mechanism in place. Use your other hand or have a partner spin the mesh/bladed bowl counter-clockwise.
With just some effort and a small "pop" noise, the piece should be free.
I searched forever for a solution, I hope someone with a similar plight finds this helpful.
Mar 15, 2010 | Salton Juicers
Open to clean juicer maching
http://www.powerjuicer.com/customer-manuals.html
This is the site to download Jack Lalanne's Power Juicer Manuals of all models which include troubleshooting guide, user instructions, cleaning and opening machine.
Jul 13, 2009 | Jack Lalanne Power Juicer (Stainless...
No user manual for breville bje510xl juicer.
Email me at ewingelectrical@optusnet.com.au and I'll email you the PDF in the morning Oz time :)
Apr 26, 2009 | Breville BJE510 900 Watts Juicer
Open to clean Power Juicer Model # CL003AP?
Hi there: have the same problem, go to www.powerjuicer.com/pdf/classic.pdf.
you will need the crescent tool which I do not have as yet but two screwdrivers work, be careful.
Nov 03, 2008 | Jack Lalanne Power Juicer 250 Watts
How to dismantle my juicer?
Simply turn the top counter clockwise like you would open a jar.
Aug 10, 2007 | Acme 5001 Supreme Juicerator Juice...
Acme 6001 Juice Extractor Logo
32 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
