Question about OnQ legrand AU5010-WH lyriQ High Performance Keypad in Studio Design -
Setting time to start reticulation on and off
Adjusting screws on optical plummet has four screws , what do they do
The adjusting screws are to hold the reticule in place. They are adjusted by loosening and tightening oppsite screws to move the dot, or X left and right, or up and down. This can be adjusted to make sure the reticule is properly centered.
Feb 16, 2014 | Seco Tribrach Adjuster
Crosshairs sights not visible
I assume, of course, you've turned the reticule focus knob, to focus on the reticule (cross hairs).
if you have, then this depends on the age of the unit. Old school optical equipment used spider silk glued to a brass rings. New equipment uses a glass lens with lines etched in them, its possible that this is too dirty to see the lines. Spider web needs to be set by a professional with an aligned collminator to make sure everything lines up. If your lens is dirty, take off the focus (either by a quarter turn ring between the focus and the reticule adjustment cover) or by simply unscrewing the focus until it comes out.
Dec 11, 2013 | Pentax Measuring Tools & Sensors
Squealing sound when it starts cycle. it quits about 1-3 minutes after.
depending on the exact model, this could be your pump on reticulate mode (I W model). when they start squealing like this, it can often lead to overheating, which will make the whole machine stop cycling.
Sep 28, 2013 | Fisher and Paykel Washing Machines
Red lights in first screen with reticule calibration crackdown 2
maybe you should check the disc and clean i did that step and it worked fine maybe its just the disc
May 06, 2012 | Microsoft Crackdown 2 for Xbox 360
I dont understand what the extra dial on my new 6-18x44 scope is for or how to use it.Or what range evry line and dot in the reticule should be ranged in at.
The third turret is for parallax and approximate range
And the lines on the reticule are round and velocity specific plus magnification comes into the distances between substension
On my scope 100 yard zero the next substension down is 176 yards at 10 magnification
The best way to use the reticule for ranging is to get a ballistics program and enter rifle round and scope stats and get a chart for that round and reticule
And the drop chart will change for different velocities and ballistic coefficients of rounds and temperatures a summer chart will be different to a winter chart due to denser air in the cold
Apr 14, 2011 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
My crosshairs have rotated yet the scope itself has not moved in its mounting. Is there an adjustment that allows me to rotate them back, or does this mean the scope is defective
You best bet is to contact Bushnell. There is no adjustment since the reticule is fixed inside the tube. The reticule should not be moving so this is a defect in your scope.
This is the Bushnell site for repairs and customer service. Contact them and explain your situation.
Apr 03, 2011 | Bushnell Banner Dusk & Dawn 3-9x40...
Is there anyway i can restraighten my riflescope reticle?
You'll need to contact Nikon. The reticule is fixed inside the tube and should not be moving. If your reticule has shifted then it's a defect.
You can contact Nikon's repair service at 1-800-Nikon US (1-800-645-6687) or check our their website here.
Mar 17, 2011 | Nikon 6456 Buckmaster Rifle Scope...
I need to find a manual for setting the Rainbow RB1 reticulation unit.
http://www.thewatershed.biz/Holman_EZY_ONE_-_Manual.pdf - had the same problem and finally found the manual!
Nov 27, 2010 | Garden
Reticulation
blocked by what?
I have to deal with iron and minials and I use the product called the works. I soak rags in the works and set it on parts that I can not reach or soak in '"works'
Apr 14, 2008 | Kenmore Elite 45986 Front Load Washer
OnQ legrand AU5010-WH lyriQ High Performance Keypad in Studio Design - Logo
19 people viewed this question
Top On-Q Legrand Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an On-Q Legrand Vehicle Part and Accessory Expert? Answer questions, earn points and help others
