Question about Toshiba 24AF42 24" TV
Is my toshiba md20f12 digital or analog? - Toshiba 24AF42 24" TV
Is Toshiba MD20FP3 an analog or digital television?
it is analog with a CRT (cathode ray tube) screen
Feb 13, 2015 | Toshiba Televison & Video
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
Is my toshiba CF35E50 a digital tv
This TV only has an analog tuner. You will need a set top box (digital to analog converter) to watch OTA TV.
I hope this helps.
Mar 22, 2011 | Toshiba Televison & Video
Will the Toshiba Model 36A42 work without a converter box?
The short answer is no. The reason for that is because it's an analog TV and has a standard tuner which is now obsolete because of the changes to all digital programming last year. You won't be able to use it with out a converter box. I won't recommend a particular brand or model, that would be your choice. Here is a selection of "boxes" available.
http://www.google.com/products?client=firefox-a&rls=org.mozilla:en-US:official&channel=s&hl=en&q=Digital+to+analog+converter+boxes.&um=1&ie=UTF-8&ei=GVSxS9WXE4-CswPd27XKAQ&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CC8QrQQwAg
Mar 30, 2010 | Toshiba 36A42 36" TV
Toshiba TV model 19A24
THAT IS AN ANALOG SET. YOU NEED THE CONVERTER BOX. FOR TRANSITION TO DIGITAL.
Jan 22, 2009 | Televison & Video
Is converted box necessary for Toshiba 27D46 tv
The Toshiba 27D46 has a digital tuner, so you should be good to go when the switch to digital occurs.
Dec 18, 2008 | Toshiba 27D46 27" TV
Analog odr Digital?
the problem you are having is a loose solder connection on vertical ic,easy fix only soldering vertical ic.tools you need solder iron and solder. but yes your tv is analog and will require a digital converter.
Jul 10, 2008 | Toshiba 36A50 36" TV
Digital or analog?
As long as you are on cable you will not need a box.
Mar 28, 2008 | Toshiba CF19G22 19" TV
Toshiba 24AF42 24" TV Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
