Question about BMW Vehicle Parts & Accessories
Mass air flow sensor - BMW Vehicle Parts & Accessories
  • 566 Answers
SOURCE: Where is the mass air flow sensor located on a jaguar x-type
hi from the uk the location of mass air flow sensor on x type jag is as follows==it is on the r/h/side of the air filter cover with jaguar embossed on top? this sensor is just prior to the intake hose that connects to the motorised throttle body from filter connections underneath it to unplug and meter is held by two screws ?if memory serves ? may i suggest you remove the large hose and use a little wd40 or similar to clean /lubricate the throttle butterfly in throttle body throat at this point so as to prevent future sticking upsetting of idling ? hope this helps ?
Posted on Dec 20, 2008
blueextc3221
  • 15935 Answers
SOURCE: location of mass air flow sensor
The sensor is mounted on the throttle body between the air cleaner assembly and the air cleaner outlet tube.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 04, 2009
mlapres
  • 757 Answers
SOURCE: mass air flow sensor
The mass airflow sensor is very important...it uses tiny diodes mounted in the flow path of the incoming air to the throttle body in units called CFM. It sends that information to the engine computer and the program calculates the proper amount of fuel needed to mix with the volume of air coming in. It is vital to your car that this sensor is properly maintained. If it's diodes are allowed to get dirty such as by having a dirty air filter, then the readings it takes will be inaccurate and the cars' performance will suffer. If the diodes break, you will not be able to drive the car and a new sensor is expensive.
DO NOT buy into snake-oil products like MAF cleaner...it is an expensive gimmick plus spraying anything under pressure into the sensor can break the diode filaments, some of them are barely .010" thick. Just remove the sensor with the proper bit and carefully poor a stream of isopropyl alcohol (isohol, rubbing alcohol) over the diodes until they shine. Then rinse with water and let air dry.
Posted on Dec 15, 2009
  • 1146 Answers
SOURCE: Location of mass air flow sensor, 2000 Grand Prix GTP
Hi:
The mass air flow sensor is a round sensor that is mounted in the air intake, between the air cleaner box and the engine throttle body.
Posted on Feb 07, 2010
Molson02536
  • 3854 Answers
SOURCE: 98 chevy suburban, code reads mass air flow sensor
Check the wire leads and clean them before reconnecting the wire leads. It wouldn't hurt also to clean the MAF sensor with MAF cleaner, the code your getting is most common to the high performance oil base filters like K&N.
Good luck and this should help you resolve your MAF issues. Thank you for using Fixya
Posted on Mar 12, 2010
Symptoms of faulty air flow sensor
  • How to Detect and Clean a Faulty Mass Airflow Sensor ... www.carsdirect.com > Car Repair > Engine Repair 2012-02-24 · Symptoms of a Faulty Mass Air Flow Sensor ... Here are some of the most common symptoms of a faulty mass airflow sensor: ... CARSDIRECT IS AN ...
  • Mass Airflow Sensor: An Easy Fix for Big Problems from a ... www.airtexproducts.com/news-blog-mass-airflow-sensor-an-easy-fix... news,blog,mass,airflow,sensor,an,easy,fix,for,big,problems,from,a,little,instrument. ... Mass Airflow Sensor: ... What Are the Symptoms of a Faulty Mass Air Flow Sensor?
  • Signs & Symptoms of a Faulty Mass Air Flow Sensor www.geeksofcars.com/list_5794328_signs-mass-air-flow-sensor.html Signs & Symptoms of a Faulty Mass Air Flow Sensor. The Mass Air Flow Sensor is a device used on many fuel injected automobile engines to measure the density of air ...
  • See Bad Mass Airflow Sensor Symptoms on YouFixCars.com www.youfixcars.com/mass-airflow-sensor.html Video embedded · Mass airflow sensor problems can turn on the check engine light. They can also cause a variety of other symptoms before the ... How to clean mass air flow sensor ...
  • How to ' Tell If You Really Need a Mass Air Flow Sensor ... www.youtube.com/watch?v=aDlHCjgYf8s
    • BY AUTO REPAIR QUESTIONS ANSWERED BY WESLEY HARRISON
    • 4 MIN
    2011-08-22 · Video embedded · ... How To Clean a Mass Air Flow Meter and Tell if you really need ... Mass Air Flow Sensor ' Auto Repair ' Wesley Harrison ... Sensor Symptoms ...
  • Videos too.,
  • Go to Bing homepage
    Jul 09, 2016 | Cars & Trucks
    2008 Chevy Kodiak c4500 duramax desiel code reader (Innova 3100 Can OBD2) shows P0102, what does it mean
    P0102 Chevrolet - Mass or Volume Air Flow Circuit Low Input
    Read more: http://engine-codes.com/p0102_chevrolet.html#ixzz38p5k1ZD8
    Possible causes - Faulty mass air flow sensor
    - Intake air leaks
    - Dirty mass air flow sensor
    - Dirty mass air filter
    - Mass air flow sensor harness is open or shorted
    - Mass air flow sensor circuit poor electrical connection
    Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor.
    Read more: http://engine-codes.com/p0102_chevrolet.html#ixzz38p5tpWZk
    Jul 28, 2014 | Cars & Trucks
    2003 Grand Am Has P0102
    It is not an ECM/PCM problem.
    P0102 - Mass or Volume Air Flow Circuit Low Input
    Possible causes- Faulty mass air flow sensor
    - Dirty air filter
    - Mass air flow sensor electrical circuit poor connection
    - Intake air leaks Tech notes Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor
    Sep 27, 2012 | 2003 Pontiac Grand Am
    Spare part 12(po100)
    P0100 NISSAN - Mass Air Flow Sensor Circuit Range/Performance Error
    Possible causes- Dirty mass air flow sensor
    - Intake air leaks
    Tech notes Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor.
    Sep 25, 2012 | 1997 Nissan Pickup
    2004 s40 ,,,,po103
    P0103 - Mass or Volume Air Flow Circuit High Input
    - Intake air leaks
    Sep 17, 2012 | 2004 Volvo S40
    ISUZU TROOPER 3.2 V6 CODE P0101
    P0101 ISUZU - Mass Air Flow Circuit Performancexicon.jpghttp://engine-codes.com/p0101_isuzu.htmlForum CodePossible causes- Dirty mass air flow sensor
    - Intake air leaks
    Jul 04, 2012 | 2001 Isuzu Trooper
    Check engine lght on and 2 codes p0103 and p0112
    P0103 HYUNDAI - Mass or Volume Air Flow Circuit High InputPossible causes- Dirty mass air flow sensor
    - Intake air leaks
    Tech notesBefore replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor.
    P0112 HYUNDAI - Intake Air Temperature Sensor 1 Circuit Low InputPossible causes- Dirty air filter
    - Intake air temperature (IAT) sensor harness is open or shorted
    - Intake air temperature (IAT) sensor electrical circuit poor connection
    - Faulty intake air temperature sensor
    When is the code detected?An excessively low voltage from the sensor is sent to ECM.
    Jun 08, 2012 | 2001 Hyundai Accent
    P0101
    P0101: MAF or VAF A Circuit Range/Perf
    - Intake air leaks
    Feb 09, 2012 | 1999 Pontiac Grand Prix
    I got the code from the OBD IT read a code of 23 and one of 36 now i need to find what it means
    code 23 is MAT too low.(mass air temp.) code 36 is Mass Air Flow Sensor Error
    The ECM receives a signal from the Mass Air Flow sensor depending on the amount of air entering the engine. The ECM uses information from this sensor to help calculate fuel delivery and spark timing.
    Fault Code Description
    • 36 - Mass Air Flow sensor error
      Symptoms
      • Engine stalling
      • Lack of power
      Common Problems Faulty Mass Air Flow sensor,Broken wire to Mass Air Flow sensor,Dirty sensing element in Mass Air Flow sensor
        May 17, 2011 | Pontiac Bonneville Cars & Trucks
        P0103
        P0103 MAZDA - Mass Air Flow Sensor High Input Signal Possible causes - Dirty mass air flow sensor
        - Intake air leaks
        Mar 07, 2011 | 2004 Mazda MPV
        Vehicle Parts & Accessories Logo
        Top BMW Vehicle Parts & Accessories Experts
        Colin Stickland
        Colin Stickland
        greg benton
        Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
