Question about Samsung SD 616E (729507925578) Internal DVD Drive
Combo drive Sir, my drive is not coming out of combo when i push a button on its front panel. only led glow for few seconds and then stops.
  • Amit Jain Oct 19, 2007
    Sir,
  • 4,889 Answers
This is due to a worn out component(looks like a tray) which raises the tray to eject..you will need to replace it..It wont cost you much..
Posted on Oct 19, 2007
How to unlock memory card password
Step 1:
to unlock memory card password, u will need a memory card unlocker device. it will cost you nearly 10$.4_11_2013_12_35_26_pm.jpg4_11_2013_12_35_26_pm.jpg4_11_2013_12_35_26_pm.jpg4_11_2013_12_37_48_pm.jpg4_11_2013_12_37_48_pm.jpg
Step 2:
now plug this device into your pc or laptop's usb port and insert your locked memory card. a led light will glow for few seconds(reading memory card). after few seconds that led light will turn off automatically and now you can press unlock button on this device. that led will glow again for few seconds. when led again turns off then you can remove your memory card and it is successfully unlocked.
Apr 11, 2013 | Lenovo IdeaPad Z560 Laptop
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
My compaq prescario CQ45 is not booting up. When I press the power on button, the LEDs are glowing. I could also hear a brief sound as if the fan is operating. After 4 to 5 seconds, the fan also stops...
There are a few reasons/causes of this.
The most common cause is the modem going faulty. Remove the modem and it may come back to life as it can't finish POST.
The Bios has an error, remove the Cmos battery and let the board discharge for 1/4 hour, re fit it and it may POST.
The uProcessor may need re seating and have a bad contact on a pin. Re seat the uProcessor and clean off old heatsink compound installing new.
Maybe as they are the most common I have come across, you may fall into one of them, I hope, otherwise it is a dead motherboard I'm sorry to suggest. Even if the RAM is faulty, it should attempt to POST.
Jan 02, 2011 | Compaq Presario Notebook
Red led flashing 6 times
Something is wrong with the power supply of the Hi Voltage section
Oct 08, 2009 | Sony KDF-E55A20 55 in. LCD Television
What do these codes mean on 1994 Cadillac Eldorado -A012 and A047
Sound like you have a bad cv "constant velocity joint " REPLACE.
The first thing you need to do is to clear your old codes then drive
and see if they come back .
1. Re-enter back into the climate control panel and after all the codes display the display will stop at PCM?
2. Push and release the FAN UP (^) button on the climate control panel and you will see PCM DATA?
3. Keep pushing and releasing the FAN DOWN (v) button until you see PCM CLEAR CODES?
4. Push and release the FAN UP (^) button and you will see PCM CODES CLEAR?
5. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
6. Push and release the FAN DOWN (v) button and you will see IPC?
7. Push and release the FAN UP (^) button on the climate control panel and you will see IPC DATA?
8. Keep pushing and releasing the FAN DOWN (v) button until you see IPC CLEAR CODES?
9. Push and release the FAN UP (^) button and you will see IPC CODES CLEAR?
10. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
11. keep Pushing and releasing the FAN DOWN (v) button and you will see ACP?
12. Push and release the FAN UP (^) button on the climate control panel and you will see ACP DATA?
13. Keep pushing and releasing the FAN DOWN (v) button until you see ACP CLEAR CODES?
14.Push and release the FAN UP (^) button and you will see ACP CODES CLEAR?
15. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
16. keep Pushing and releasing the FAN DOWN (v) button and you will see SIR?
17. Push and release the FAN UP (^) button on the climate control panel and you will see SIR DATA?
18. Keep pushing and releasing the FAN DOWN (v) button until you see SIR CLEAR CODES?
19. Push and release the FAN UP (^) button and you will see SIR CODES CLEAR?
20. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
21. Push the AUTO button to get out of diagnostics.
22. Turn ignition OFF for 15 seconds.
23. Re-enter diagnostics and see if any history codes re-appear.
Mar 27, 2009 | 1994 Cadillac Eldorado
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
No heat
Check the glow plug.
Take off the bottom front panel, push the start button and look for a red glow. This glow plug is about the size of your little finger and is hard to see when it's off but you will see a red glow if it's working. No glow, replace the glow plug.
If it glows for a few seconds then goes out then the solenoids on the gas valve should be checked with an OHM meter.
Dec 16, 2008 | Dryers
Toshiba TV
Will not power, led blinking
check R640 (1K 1/4w) if open replace ic600 (8-759-670-30)
Standby led blinks slowly, a few times, chassis won't start up
I changed the vertical deflection ic type TDA8170 and I measured two leaky capacitors in the power supply. Better to change all 4 capacitors in the power unit, everything was then ok !
Nov 24, 2007 | Toshiba MD13P3 13 in. TV/DVD Combo
Samsung SD 616E (729507925578) Internal DVD Drive Logo
95 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
