Question about Irons
Laurastar magic s4 doesn't steam
The iron heats up but no steam, the boiler doesn't operate.
5 Suggested Answers
  • 4088 Answers
SOURCE: I have Laurastar steampump model 01-0165. How
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
Posted on Aug 01, 2009
SOURCE: my new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
Posted on Feb 16, 2010
ercupa190
  • 12223 Answers
SOURCE: steam boiler iron
you can download instr. manual from www. fitness.manualsonline.com or www.retrevo.com or www.manualsfactory.com
service manual go www.pdfservicemanual.com
God bless you. However see the diagram is universal for repair small appliances.
Posted on Jul 26, 2012
ercupa190
  • 12223 Answers
SOURCE: My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Posted on Nov 15, 2012
How can i dismantle a laurastar s4 iron?
not really-- use the correct iron cleaner and if that doesn't work, the damage done dismantling the iron will require a new unit any way
May 11, 2016 | Irons
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
I have a lauraStar Magic Evolution and Steam is escaping around the filling cap. Alot What do I need to do
rubber fittings destroyed in internal compartment,ervice by expert professional
Jan 12, 2015 | Irons
Wet steam coming out of iron
You have to take part the iron by unscrewing the three bolts on the side handle with a small phillips driver. Then loose the allen screw on one side of the black thermostat wheel to unloosen it. Then take out the two bolt plastic protectors under the handle and unscrew the two allen bolts, carefully separate the top from the botton of the iron, carefully not to pry loose the cables from the top to the hot shoe.
On the back you will see a small white square box, that is the thermostat, which has a button on top, all you need to do is to push it in. This will make the iron heat up unless you have a thermostat failure (Black wheel with temperature indicators), which you will need to order the part and change it.
Mar 07, 2013 | Reliable i30/120V Professional Steam Iron...
Nov 14, 2012 | Irons
Bosch TDS 1445/05 Sensixx station doesn't making steam
HI!
I HAVE AN Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL. I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK. THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
Oct 06, 2012 | Irons
My new laurastar steamer is not producing steam at
Nov 13, 2009 | Irons
The boiler part is working fine but i have no
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 25, 2009 | DeLonghi Stiromeglio Compact PRO 300 Iron
Aug 01, 2009 | Hamilton Beach Steam Excel 14770 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Irons Logo
55 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
