Question about Maytag Atlantis MDE7400AY Electric Dryer
Moved dryer, hooked up wrong, not working now after re-hooked up
I recently moved my maytag atlantis dryer down 6 flights of stairs by myself with a dolly...hooked it up, turned it on , noticed that it wasnt heating...took a look at the wiring, realized i accidently hooked it black to red instead of red to black; re-adjusted them now it doesnt heat still. Please help me, what should i do?
  • 20 Answers
Have you check outlet with a voltmeter or even checked breaker? Is your new rect' a 3 or 4 prong outlet? If you hooked up red's to black and black to reds it still should have worked. The 220 volt heating element is between the red's and blacks the 110 circuits would be between a red or black to white wire.
Posted on May 21, 2009
My maytag atlantis model #MDE6200ayw Serial #40504320zy is not getting hot. Everything else seems to be working fine. One thing i did have to do was change the prog back to the 3 prong as i just moved into...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
My mde7600ayw is a 3 wire 120/240 v 60hz 5600w.
Hi, yes that is the correct cord all right. If you'll notice the new cord has 2 hot (red & black) a neutral (white) and ground/earth (green) wires. In case you are not sure how to connect I've attached a photo which shows the correct way. If my attachment didn't work, check out you-tube and type in "4 wire dryer hook up". Thanks for visiting "fixya" and good luck macmarkus :) IMG_3336.JPG
Apr 19, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Atlantis washer stopped working after moving?
maybe the hose came off the water level switch,,,just remove the screws in each end of the control panel,,some machines you have to remove the panel end caps to get to the screws,,,,then pull slightly forward and flip the panel back to access the level switch,,,,,,my hose came off 1 time and flooded the kitchen lol,,,,but air pressure coming through the clear plastic hose kicks off the water coming in and allows the timer to move forward to next cycle!
Apr 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
We moved the dryer in and turned it on. There was
Sounds like the motor shorted. Pull it apart and look for burnt wires and/or a burnt motor. The motor itself will smell burnt if it is.
Dec 13, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Toshiba BD-7610 copier moved the copier down a
take the developer unit out carefully shake back and forth free spin the gears by hand clean any spill inside might work in the future remove dv and drum b 4 moving
Apr 09, 2009 | Toshiba Office Equipment & Supplies
Recently moved, light inside dryer works. does not turn nor heat
Don't be playing around with electricity, folks. If you use anything but original equipment and something goes wrong, it's all your fault and responsibility. You are renting, have the landlord approve and maybe he can recommend a proper solution.
Mar 24, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replacing Timer on Maytag Atlantis Dryer
Call a local appliance shop and ask about it. Maytag is pretty common and available. The timer will be about 75 dollars. It could be more depending on what all you have on it. It is pretty easy to replace once you get to it. Let me know how this turns out.
Jan 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Rear projection - only blue lamp works, after set was moved
since you moved it i would look for a loose connection or loose board and loose plugs
Dec 22, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Maytag Atlantis MDE7400AY Electric Dryer Logo
163 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
