Question about Dell Computers & Internet
Dell desktop 520 doesnt recognize hard drive - Dell Computers & Internet
  • 25 Answers
Sounds like a bad hard drive or a BIOS problem. If you have access to a working PC, try connecting the hard drive (providing the connections match) and see if it's recognized. Try borrowing another hard drive to see if your machine recognizes that one. Your bios is a good place to begin.
Posted on Apr 24, 2014
bob_computer
  • 3153 Answers
SOURCE: New Dell desktop can't recognize external hard drive
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Aug 28, 2009
  • 139 Answers
SOURCE: Dell Optiplex GX1 not recognizing all hard drives.
If you connect the drives using one single ribbon cable with two connectors on it then you need to set the drives to Master/Slave using the jumpers on the drives. Master being your OS drive.
If you are running a very old Operating System, make sure it can support a 20GB drive.
Posted on Jan 07, 2010
  • 73 Answers
SOURCE: Dell optiplex will not recognize hard drive
Is it SATA or IDE? Have you tried another cable? If it's IDE, have you checked the jumper settings (usually Cable Select is easiest)?
Posted on Feb 19, 2010
  • 93 Answers
SOURCE: does not recognize hard drive
hi
thank you for using fixyz
chack your HDD cable wich conacted with your motherboard may it's not working or replace that then try
still there is prob then may you HDD is not working
Posted on May 13, 2010
Sea Breeze
  • 4654 Answers
SOURCE: Can't get Dell Desktop to recognize cd/dvd on D: drive
With any computer this is a question that must be answered by those that provide the driver software. Like the number above (Dimension 3100) you should begin your search here=> Dimension 3100 Drivers that is if you have not altered the driver by putting a different player in the slot. What you need to do is test the drive using the Dell diagnostics. The procedure can be found in the CD/DVD FAQ. Run the "read test". You'll need to insert various disc types during the test.
This came from Dell Forums. Click Here=> Dell Forums/Osprey and Here=> Search Results for "Dimension 3100 DVD Driver"
Hope this helps, Thanks, Sea Breeze
Posted on Jul 14, 2010
My Dell System Optiplex 520 having 160 GB Hard SATA disk drive. when i turn on my PC then show error : auto sensing second slave hard disk drive" i restart my PC several time then Turn on my PC window....
Go to BIOS by pressing the F10 button(may vary product to product).
check the boot option, it might be changed, you need to change it for 160 GB hard disk.
If it does not works, then it might be the failure of harddisk.
Contact you Vender in this case.
Mar 12, 2014 | Dell Dimension E520 PC Desktop
OptiPlex GX400 can't find the CD drive and can't find the hard drive
hey, if the machine boots into windows but doesnt show the cdrom drive in my computer, might be you have had norton on in the past theres a common fault that makes the drive disappear, the fix is on this page http://www.facebook.com/l.php?u=https%3A%2F%2Fwww-secure.symantec.com%2Fnorton-support%2Fjsp%2Fhelp-solutions.jsp%3Fdocid%3D20090430144107EN%26lg%3Denglish%26ct%3Dunited%2Bstates%26product%3Dhome%26version%3D1%26pvid%3Df-home%26entsrc%3Dredirect_pubweb&h=jAQEyPa4V
if the drive aint showing in the bios, make sure you have the jumper on the drive set correctly to either slave or master depending on how its cabled. hope this helps ;)
Jun 12, 2012 | Dell OptiPlex GX400 PC Desktop
Does not recognize hard drive
hi
May 13, 2010 | Dell Dimension 8250 PC Desktop
Feb 19, 2010 | Dell Optiplex GX60 PC Desktop
Jan 07, 2010 | Dell OptiPlex GX1 PC Desktop
No display on the Dell Dem 520
IT SOUNDS LIKE HARD-DRIVE FAILURE, TRY REINSTALLING THE OPERATING SYSTEM, BUT IF IT DOES NOTHING THEN REPLACE THE DRIVE
Jun 16, 2009 | Dell Dimension E520 PC Desktop
Dell 2400 wont recognize harddrive
I don't know how old the Dell is but I have not seen a BIOS setup routine that did not automatically find and recognize a new hard drive for many years. Perhaps the BIOS is the source of the problem.  Did you try the removed drive in another system? Did you check the CMOS backup battery? If this needs to be replaced, it may not recognize much of anything.
Dec 22, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
