Question about Air Tools & Compressors
Parts manual for a sanborn 3/8 inch drive air ratchet
Model 9504?
    Habit-Forming:
  • 174 Answers
I found a web site that sells Sanborn. try going to this web page and contacting them surley they can help you out since they sell that brand.hope this will help you, https://www.menards.com/main/tools-hardware/power-tool
Posted on Sep 14, 2016
How to change oil in sandborn compressor?
Coleman/Sanborn Compressor Owners Manuals - Air ...
www.aircompressorpartsonline.com/coleman-powermate-and-sanborn-ai...
Coleman/Sanborn Compressor Owners Manuals. Download to your computer and keep it handy. - Air compressor parts for most makes and models of air ...
Sep 12, 2015 | Air Tools & Compressors
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
Need a manual for a Ingersoll Rand Model 111
If you go online to Ingersol Rand, click on air tools. You should be able to find the IR-111 knuckle saver ratchet. Once there you should be able to click on a link that opens up the exploded view of internal parts. Otherwise go to your local air tool repair centre, they can help.
Feb 21, 2012 | Ingersoll Rand 111 The Knuckle Saver 3/8...
How to instal an alternater?
It all depends on the model and year. The alternator is on your main belt. It has two electrical connectors and probably a bolt or two for placement.
Feb 04, 2011 | Chevrolet Monte Carlo Cars & Trucks
I have a Sanborn Black Max 22 gal. compressor Mod#B109BLR300-22SWC. The motor is a Magnetic/Century 3 H.P. 115v Model 8-165730-20 Ser# BF-532 15A-7.5 RPM 3450. It is missing the run and start capacitors....
Sanborn/Coleman was bought out by MAT Solutions. A website I found lists Sanborn/Coleman compressors and parts but it does not show your model number. It does say, however, to email them with your model number and they will be able to find your parts for you. I have included the link for you here: http://www.mastertoolrepair.com/colemansanborn-portable-parts-freedirect-drive-electric-c-271_35_172_178.html
Sep 10, 2009 | Air Tools & Compressors
Replacing timing belt on daewoo nubira 2000 model
Instructions Difficulty: Moderate Things You’ll Need:
  • Set of ¼-inch drive sockets ¼-inch drive ratchet Set of ½-inch drive sockets ½-inch drive ratchet Set of 3/8-inch drive sockets 3/8-inch drive ratchet Set of metric wrenches Floor jack Jack stands
Step1 Raise and support the vehicle on jack stands. Remove the intake air temperature wiring, the breather hose and intake air hose. Take off the air cleaner assembly. Step2 Remove the right wheel. Remove the accessory belts. Remove the crankshaft bolt and the crankshaft pulley. Remove the power steering bolts and the timing belt covers. Temporarily install the crankshaft bolt and turn the engine clockwise until the mark on the crankshaft pulley, which is a triangle stamped into the crank sprocket, is aligned with the corresponding triangular mark on the block. Step3 Make sure that the timing marks are aligned on the camshaft sprockets. These are a line on each sprocket that runs through a tooth on each sprocket. These lines should line up in the middle between each sprocket and point toward each other. If they do not line up, turn the crankshaft one more time and they will line up. It takes two turns of the crank to one complete revolution of the cam. Step4 Loosen the water pump bolts; using the 3/8-inch ratchet, turn the water pump clockwise away from the belt and loosely tighten the bolts to keep it there. Remove the timing beltmag-glass_10x10.gif. Make sure the timing marks are aligned and install the new belt starting on the right side from the crank sprocket and working counterclockwise. Keep all the belt tension on the right side away from the tensioner. Step5 Loosen the bolts in the water pump and rotate the water pump counterclockwise to apply tension to the belt. Watch the tensioner, which is above the water pump, and apply tension with the water pump until the pointer on the tensioner lines up with the notch above it. Lightly tighten the water-pump bolts. Step6 Turn the engine two more times and align the timing marks perfectly. Loosen the water-pump bolts and, using the ratchet, apply tension to the belt until the tensioner pointers are aligned. Tighten the water-pump bolts. Step7 Install the timing-belt covers and the bolts in the power-steering pump and tighten. Remove the crankshaft bolt and install the crank pulley and the bolt, then torque the crankshaft pulley bolt to 70 foot pounds of torque. Install all components in reverse order of removal.
Mar 02, 2009 | 2000 Daewoo Nubira
Sanborn air compressor parts needed
www.arkansas-ope.com/SANBORN_AC_PARTS.html -
they have sanborn parts
Oct 10, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
552 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
