Question about FrancisFrancis! X1 Espresso Machine
Francis francis espresso wont pump water but steamer works?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
The main problem with coffee machines is they get furred up with limescale. If you let it go too long they can stop working like this. It's not difficult to take the machine apart if you're mechanically inclined and then you can clean each part.
Posted on Jan 23, 2015
SOURCE: fRANCIS Francis espresso problem..just barely coming out..
Try removing the metal grille from the machine. I don't know the term, but it's held in with a single allen screw on the underside of the machine. Don't use the allen key that FrancisFrancis provide, it's made of soft metal and useless. Buy a decent one.
I did this, and found coffee 'goo' a millimetre thick on top of this sheet of metal. Once I'd cleaned it off it was fine. To clean it, I put it into a cup and soaked it with Mr Muscle oven cleaner, left it for an hour, and then scrubbed it clean. I ran a sewing needle across the back to help clear the pinholes.
Posted on Jan 05, 2009
EsWorld
  • 1618 Answers
SOURCE: Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
Posted on May 20, 2009
EsWorld
  • 1618 Answers
SOURCE: Francis francis milk steamer not operating
Check the end/nozzle of the steam wand, if you open the wand and while getting nothing it is hot, then the nozzle is blocked use a paperclip to clear the hole at the end of tip. If you have done this already and still no steam then it is clogged where the steam valve connects to the boiler.
jmgldsmth
  • 2005 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
smartr10U
  • 1305 Answers
Steamer tubes can get plugged up with dried milk and/or calified water deposits in the tube.
With the machine unplugged, turn the tube up to check it, Clean it with a small guage wire.
Soak it in a small cup of vinegar, if needed.
Further cleaning, you can add a bit of vinegar to the water and steam it thru...
Let me know how it goes.
K
Posted on Jun 03, 2009
I have a Francis Francis x1 machine, but when i want to make an espresso shot, and turns on the espresso button, the steamer spour out boiling water (not steam, and not while turned on). Does anyone k
Don't know how your controls are set, but you have two switches on the front and a knob on the right. The switch for the steamer (the right hand switch) should be off. The knob on the right should be turned clockwise to turn in off. Then no water or steam should come out of the steamer wand. If it does, the seal on the knob inside the machine is broken. It can be repaired but only if you're handy with a screwdriver (make sure if you take it apart you disconnect it from the mains).
Jun 24, 2014 | FrancisFrancis! Coffee Makers & Espresso...
I bought a second hand Francis Francis X1 Espresso Coffee Machine & the gauge & Milk frother are no longer working. Any advice?
Perhaps the heating element is broken. Does it heat up at all? If not, the steamer won't work and there will be nothing for the gauge to register.
Feb 02, 2010 | FrancisFrancis! X1 - Stainless Steel...
K
Jun 03, 2009 | FrancisFrancis! X1 - Stainless Steel...
May 19, 2009 | FrancisFrancis! X1 - Stainless Steel...
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Francis francis x1, blocked steamer
Pour in a solution of 50% distilled white vinegar and 50 % water. Set the steam wand knob to a water setting, and run the solution through there. I would suggest letting a small amount of the vinegar/water solution drip out, then cut the machine off for about 20 minutes - allowing the vinegar to thoroughly soak and decalcify the insides. After 20 minutes, let the remaining vinegar/water pour through.
If the problem persists, Francis Franic is now owned by illy - 1-877-469-4559
-Tha Mp3 doctor
Oct 05, 2008 | FrancisFrancis! X1 Espresso Machine
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
Steam Wand Broken
Something is stuck inside the wand. Get a small pice of wire or small paperclip and inset and try to clear the blockage
Nov 12, 2007 | FrancisFrancis! X3 Espresso Machine
FrancisFrancis! X1 Espresso Machine Logo
151 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
