Question about Kensington Comfort Type Wireless Optical Desktop Keyboard 64355
Keningston wireless key board pairing code
Pairing code I need the Bluetooth pairing code
Bluetooth pairing codes
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
Oct 06, 2012 | Radio Communications
Pairing code for dell wireless 370 bluetooth mini-card
Normally when pairing with any device, any pairing code can be applied (4 digits),and then when asked on the other system, the one applied on the first system, will be required to put in. In most of the cases, it is pre defined as 0000
Jul 06, 2012 | Computers & Internet
Im trying to put a bluetooth on my phone and it finds it but it says pair and when i click pair , it askes me for a pairing passking key? what is that or what do i do?
Hello, Unless you saved a bluetooth pairing password in the past, this code should be four (0) zeros. Please leave positive feedback if it works out for you. Thanks and Good Luck. =)
Jan 29, 2011 | Motorola Mobility H700 Wireless Headset
Pair my Sony Ericsson bluetooth HBH-PV703 with Pantech Impact cell phone
You must put your headset in pairing mode first. Starting with it turned off, press and hold the call handling key until the indicator light flashes alternately in red and blue. Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the headset should enter the stand-by mode, and there should be some indications on your phone too.
The pairing process between any two bluetooth enabled devices should be done only once. All subsequent connections should be achieved by turning both your headset and your phone's bluetooth radio on and bringing them both into each other's range. At most, a single press on the headset's call handling key should do.
Hope it works for you.
By the way, if your headset's user guide seems to be missing, feel free to download it from this location.
Please, let me know if you need further informations.
Regards, Carlos
Sep 25, 2010 | Sony Ericsson Genuine Bluetooth Headset...
Please help pair my Explore 233 to a Samsung T-mobile
The default pairing code for Plantronics is 0000 (4 zeros). If you need more help, try their interactive pairing guide: http://www.plantronics.com/media/media_resources/easytopair/
Sep 01, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Pair bluetooth em227 with my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Mar 05, 2010 | Southern Telecom Emerson Bluetooth Headset...
Bluetooth Pairing code
pairing code or pass word for my plantronics220 bluetooth ear piece
Mar 12, 2009 | Plantronics Explorer 220 Bluetooth Headset...
I don't have the code for my sony wireless dr-bt22
Trying pairing with a PC. Pairing defect key is 0000. Good luck.
Jan 29, 2009 | Sony Bluetooth Wireless Headset for...
Kensington Comfort Type Wireless Optical Desktop Keyboard 64355 Logo
32 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
rey francis basa
rey francis basa
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
