Question about Nuheat SOLO Thermostat
Nuheat solo thermostat is flashing and system is not working
The solo thermostat of my nuheat floor heating system is flashing intermittently and the floor is cold
Blower motor on Trane 4TEE3C04A1000AA not coming on.
could be a number of things. heat may have blown a fuse now nothing works, heater may not have worked because the blower wasn't. you need a meter to test voltage.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 15, 2018 | Heating & Cooling
Nuheat thermostat keeps rebooting
replace the thermistat module..sounds like it has a bug in the firmware
Jan 08, 2014 | Nuheat Harmony Thermostat
The screen of Nuheat Solo keeps flashing, the floor is cold. It seems like that the whole system stop operating. Yesterday, it was fine.
I had the same problem. It is caused by a failure in the thermostat, usually brought on by a power surge. Unfortunately, this product is poorly designed, and cannot handle common power surges in homes. The only solution is to replace the thermostat unit. Nuheat has a decent warranty (3 years) so you may qualify for a free replacement.
Dec 22, 2013 | Nuheat SOLO Thermostat
Baxi he 24 solo. Local Gas safe Engineer has replaced pcb, condensate trap, overheat and other thermostat, also igniter/sparker and flame failure sensor, Boiler still intermittently locking out (red...
Sounds like its an intermittent flame failure on trial for ignition. Look for the pilot flame drifting away from the sensor when the main valve opens.
Nov 24, 2013 | Heating & Cooling
Honeywell T8400B Thermostat Display Intermittently Blank
most likely a bad tstat i would replace I recommend honeywell focus pro 6000
Jan 29, 2009 | Heating & Cooling
Nuheat SOLO Thermostat Logo
972 people viewed this question
Top Nuheat Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Nuheat Heating and Cooling Expert? Answer questions, earn points and help others
