What kind of hard drive USB enclosure adapter use on toshiba c650
robshow
  • 367 Answers
SOURCE: USB Enclosure needed for Maxtor N256 Hard Drive
CLICK HERE FOR a suggestion from newegg.com Pretty cheap as well
Posted on Jan 20, 2009
Chinthakaj
  • 416 Answers
SOURCE: Can't open hard drive enclosure
A Details Guide too remove the Disk.
http://www.gearhack.com/myink/ViewPage.php?file=docs/AcomData%20E5%20HybridDrive%20External%20Hard%20Drive%20Disassembly
Posted on Feb 02, 2009
Benimur
  • 6966 Answers
SOURCE: Which USB enclosure for Seagate U6 Model ST360020A (60GB)
Hi and welcome to FixYa,
Would suggest a multiple to 1 adapter that would accommodate most if not all types of connection. The price difference would be negligible and since its multiple would work on just about any IDE, SATA, 2.5 or 3.5. A good example is this model.
Good luck and thank you for using FixYa.
Posted on Feb 08, 2009
Geekman
  • 32281 Answers
SOURCE: What kind of enclosure and cable do I need to make my drive exter
This drive is an IDE/ATA hard drive.
To use this as an external hard drive, I suggest you purchase an USB hard drive adapter case (with an USB cable) and install the hard drive into this case.
When you plug this adapter into the USB port of a computer, the computer will see this as an external hard drive.
Posted on Mar 22, 2010
SOURCE: Open hard drive enclosure
(I found your question because I had the same question. Decided to go for it.) The aluminum top and bottom covers are held in place by the indentations on the sides which fit into channels on the plastic chassis inside. I used a flat knife blade to gently pry by the front end of one side until the cover moved moved slightly out of the channels, then switched to the other side. Once I had it started, I was able to just lever the cover off by grasping the front corners and swinging it up in the reverse motion of the installation procedure. Caution: Prying too hard or far at once will bend the covers and or nick the plastic chassis extrusion. Good luck
Posted on Aug 11, 2010
Help my laptop isn't working
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 06, 2013 | Computers & Internet
My Toshiba HDDR500E04XL 500 GB causes my pc to hang when reading from it, tried it on 2 other pc's and same thing happens. Can the Drive be repaired?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Jan 06, 2011 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Hi! i have an external hard disc Toshiba PX1396E-3T01. i've connected the divice to my pc but the red light doesn't turn blue but instead keeps on blinking blue. what's wrong?
* the USB cable
* the power-adapter
Dec 23, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
I have a Toshiba 1tb external drive. It wont turn on, light will flash a couple of times but will not turn on, please help
* the USB cable
* the power-adapter
Nov 18, 2010 | Toshiba 20GB 5400 RPM NOTEBOOK HARD DRIVE...
I have a old TOSHIBA 80GB external hard drive , i dont have the model number the problem is whenever i try to access the hard drive it shows that the hard drive is enabled but on my computer it appears...
* the USB cable
* the power-adapter
Nov 18, 2010 | Toshiba Computers & Internet
I have 500GB Roco (Toshiba) external hard drive... It was not dropped or physically damaged. My desktop and my laptop don't recognized it anymore. What seems to be the problem and how can i fix...
* the USB cable
* the power-adapter
Nov 10, 2010 | Toshiba 120GB USB 2.0 Portable External...
Dear all, My toshiba external hard disc (640GB) is not working properly. the problem is that the disc is detected by the computer and i can see the data for first 5 minutes and after that light in the...
The device has four major components:
* the USB cable
* the power-adapter
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, to "check warranty status" -- if it is still under warranty, you can get a replacement, at minimal cost to you.
Nov 07, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Mar 22, 2010 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
How can i make my seagate hard disk an usb hard
It is quite easy, do not worry.
You only need to bought and USB enclosure, here is a link to many products on ebay
http://search.ebay.com/search/search.dll?from=R40&_trksid=p0.m37.l1313&satitle=hard+drive+enclosure+usb&category0=
then you have to connect your hard drive inside the enclosure and the enclosure to your computer using the usb cable and that's it.
Just be carefull about the enclosure, I guess it is a Hard drive from a desktop, is in it? because some enclosure are for laptop's hard drive.
Also you need to know if your hard drive is SATA or IDE, IDE is the normal gray bus cable with fourty some pins, and the SATA it is a really small cable (I do not use technicims to not confuse you even more).
Also, there are some adapters from IDE/SATA to USB that you can buy in your local computer store (do not go to bestbuy, compusa, ... they only sell external hd), or also get it from ebay.
The only diference between the enclosure and the adapter is that the enclosure looks better :D, and the adapter is just a bunch of cables.
Mar 19, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
