Question about Upgradeyourauto 2008-2012 Toyota Sequoia no Passenger Keyhole 4dr Chrome Door
Brake lights stay on with 2008 Toyota Sequoia
Brake lights won't turn off even when car is in park and the key is turned off.
  • 451 Answers
Check to make sure the brake pedal is in the fully upright position. Check the brake switch to make sure it is not stuck. Hope this helps.
Posted on Jan 03, 2014
Key won`t go into ignition
Try a little WD 40 , make sure your in park , also makesure your switch is in right position sometimes turning the steering wheel will help with that. Good luck
Mar 11, 2015 | 2004 Toyota Sequoia
Mazda 323 park brake light won't turn off
Theres a little switch that activates the light. It could possibly be sticking
Mar 18, 2013 | Mazda 323 Cars & Trucks
There is a brake light switch on back of the brake pedal arm that needs replaced
Oct 30, 2012 | 2007 Toyota Sequoia
Parking brake light won't go off after releasing brake lever
Park brake lights normally operate by a small plunger type switch the turns off when the level or pedal is placed in the off position. Over time the spring in the lever weakens and placing the lever in the off position no longer depresses the switch. The switch can sometimes be adjusted to make better contact, or the switch bracket can be bent so the lever and switch make proper contact.
Feb 17, 2012 | 1992 Toyota Pickup
Sequoia parking light
The brake light switch is sticking on, the switch is located under the dash above the brake bedal, replace it.
Feb 17, 2012 | 2001 Toyota Sequoia
I have a 87 toyota pickup that the alt. warning light and the brake warning light come on dim when the key is turned on, and stay on. When I set the park break they both turn bright. I have checked the...
The alternator is bad, this is the way foriegn car makers do things, when the alternator is bad or going bad and if it has a bad diode the dash lights will light up like the batt and brake and sometimes even other waring lights, replace the alternator and the problem will be sloved. good day,
Mar 26, 2011 | Toyota Pickup Cars & Trucks
Describe your ignition wont turn on sequoia Problem wiggling wheel rocking car in neutral all don't work. Help stranded
I think you need to try this in park not neutral-keep your foot on the brake, and put the shifter in park, then try turning the wheel slightly, and turn the ignition key.
Jan 26, 2011 | 2002 Toyota Sequoia
Parking brake won't hold vehicle on incline. Dealer says it's not supposed to have that much force. Isn't this wrong? 2003 Toyota Sequoia with just driver
NO, the dealer is correct,the handbook says always put the car in gear/park and turn the wheel toward the kerb when parking on an incline.this is because most cars have discs all round and after use the rear discs will shrink allowing the brakes to be inefective.(VW/hyundai/toyota will not cover you if your car runs away on its own........
Apr 21, 2010 | 2003 Toyota Sequoia
1999 Toyota Corolla Seca - hatchback. the tail
If you put your foot on the brake, the tail lights and parking lights will still come on. Possibly your brake is sticking. Check to see if it is and if it is put WD40 for a quick fix. See a tech for them to fix your brake alignment. Good Luck!
Jul 26, 2009 | 1999 Toyota Corolla
2001 Toyota Sequoia VSC and TRAC OFF lights are on
I did research on line and all indicates that is caused by the YAW RATE SENSOR. It nedds to be replace and adjust. I have the same problem but havent find the time to get to it. When I do I will post it. If you do it before I do please email me with the result at solrako@yahoo.com
Good luck
Jun 01, 2009 | 2001 Toyota Sequoia
Upgradeyourauto 2008-2012 Toyota Sequoia no Passenger Keyhole 4dr Chrome Door Logo
60 people viewed this question
Top Upgradeyourauto Computers & Internet Experts
David Payne
David Payne
Are you an Upgradeyourauto Computer and Internet Expert? Answer questions, earn points and help others
