Question about Dell 3100cn Laser Printer
Loud Abnormal Sounds with each print job
Dell 3100cn Printer makes loud almost groaning sound each time it prints. Sound seems to be coming from the back panel.
  • 10 Answers
It may be a paper feed issue. If using a duplexer, try removing the duplexing unit and try printing again. It's often attached to the back of a printer.
Posted on May 29, 2009
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
Rollers make a loud noise when printing...do we need new rollers
Does it make a groaning sound, when picking up the paper from the cassette tray? If it does, sounds like you need to order a set of feed rollers. You can tell if there worn down, just by feeling if there's still some treading, just like a bald tire. Good Luck!
Jul 04, 2010 | Dell 1720dn Laser Printer
I have a dell 3100cn every time i try to print its says job too large no memory how do i clear memory from printer
this normally means the size of the job exeeds the memory of the printer, you can try this but if it works it will probably take a long time to print:
go into your printers window in your control panel right click on the printer and choose properties in the properties choose advanced and put a check mark in print directly to printer.
this will bypass the spooler
Mar 23, 2010 | Dell 3100cn Laser Printer
96 Grand Am Groaning
Sounds like the power steering pump failing. If it seems to be worse when you turn the wheel at a stop, it is time for a new p/s pump.
Jun 26, 2009 | 1996 Pontiac Grand Am
When printing, the printer makes a loud sound
I first guess that it is the drum going out. If you have changed the drum......it is more than likely your fuser. Have you ran a supply check to get the status on your supplies?
Feb 18, 2009 | HP LaserJet 2840 Printer
Ram disk
Stangowner, In this case, the print job is too large for the available printer memory. Your choices are one of the following: Press to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the current print job. · Press Menu to open the Stored Print and delete the current job. To avoid this error in the future, do the following: · Reduce the number of print pages such as splitting the print data. · Increase free memory space by deleting unnecessary data in the RAM disk. As for the RAM disk: When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory. When you are ready to print the job, you must go to the printer and use the operator panel menus to identify which job in the memory you want to print. You can use this function to print a confidential job (Secure Print), or verify one copy before printing additional copies (Proof Print). NOTE: The printer holds the job until you delete it by using the operator panel or you turn off the printer. (This is the RAM disk) NOTE: Print and Hold functions require a minimum of 320 MB available printer memory. Also, you need to configure the RAM disk settings on either the OPERATOR PANEL OR THE PRINTER DRIVER. NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs. Take this link and print it out. It will help you later when you get "other" error messages. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html And here's a link for more "operational" situations. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section16.html#1087088 ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
247 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
