Question about Electro Brand Televison & Video
Tv stuck scanning channels - Electro Brand Televison & Video
Stuck on one channel
Is it the tv's remote? Change the batteries
are you on a cable box? You need to use the providers channel changer. Tv is made to stay on one channel like channel 3 and the cable box runs the different channels.
Dec 01, 2015 | Vizio L32 32 in. LCD HDTV
Tv stuck one channel
Be sure tv is set to antenna and not cable . Do auto scan . Find this in setup menu. If this does not work check the mfc website for software update. replace the main board as last resort.
May 29, 2013 | NEC Televison & Video
Cant change channels with remote or side of tv - sound works fine . stuck on espn - no other channels work (i quess being stuck on espn is fine but this is an office tv for thr girls while they are eating...
Your TV is most likely locked to that station because it doesn't have any other channels programmed in.
In the menu for the TV, run a channel scan. This will take probably 30-45 minutes for most TVs and will program the available channels into the TV so that they become available.
Mar 15, 2011 | Vizio VO47L 47 in. LCD TV
We have a jvc tv with built in freeview ; yesterday we got the message on the screen pr list empty and now are stuck with 5 channels and no freeview ; how do we sort
What service company do you have for your TV? Is it dish network or direct tv etc. You can do a channel scan once you verify the service company. A cable service provider will only provide 99 channel to scan/sort while a satellite service provider will provide you more channels to sort/scan.
Aug 23, 2010 | JVC GD-V4211PCE 42 in. Plasma Television
My samsung lcd television is stuck on one channel on digital input, so I am watching analogue. can you help?
First of what is the exact model of your samsung tv, Also what do you mean its stuck on one channel on digital input? What input are you using? If its standard cable, have you set the tv to catv and done a channel scan?
Thank you,
Lee
Mar 15, 2010 | Televison & Video
Tv turns on and channel continually scans
Sounds like you have a collapsed channel up or down button, Does each button have a good "rebound"?
if any of the buttons are stuck in, just release them
Mar 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
JVC LT 32E479 UNABLE TO SWITCH ANY CHANNELS
go to menu select TV settings select add a channel  In the scan boxes  type 1 and 3 or what every you have your Satellite set to  Then hit start scan  The TV will come on reset to channel 3.
Jan 14, 2009 | JVC LT-32E479 LCD TV
Channel scanning
SEEMS LIKE CONTROL PANEL SWITCH, ONE OF THEM IS STUCK OR DEFECTIVE, CONTROL PANEL NEEDS TO BE TESTED
May 11, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
23 people viewed this question
Top Electro Brand Televison & Video Experts
Electro Med Services...
Are you an Electro Brand Televison and Video Expert? Answer questions, earn points and help others
