Question about Equity Time USA Measuring Tools & Sensors
Unite beeps every minute, All readingd are accurate, alarm is off
Firex smoke alarm won't quit beeping?
After you change the battery it will continue to beep every minute or so for about 20 minutes then return to normal operation..
Mar 17, 2017 | Home
How do I reset the alarm on a 2005 hyundai Santa 2.4l
Not sure about yours, but many will reset by: turn key to "on" and wait 15 minutes or so; shut off, then try to start.
Apr 15, 2016 | Hyundai Cars & Trucks
Frigidaire PHS69EJSSO beeping and no lights aon controls
Hello rkmiller2549 - Typically when the refrigerator is beeping or buzzing it indicates a warning of a possible malfunction or an unsafe temperature inside. Usually to silence the buzzer, press the ALARM OFF button. However, if you have already done so try unplugging the unit or flipping the household circuit breaker off to reprogram it. Wait approximately ten minutes and restart refrigerator. If it proves to be ineffective, contact a professional to move forward accurately. The unit could possibly be experiencing a communication problem with the temperature control board/switch or wiring failure.
Jan 22, 2013 | Frigidaire Professional Series PHS68EJSB...
My deep freezer wont freeze..it keeps beeping..what do i look for to find out how to fix it??
Hi monilvsjay - Typically when the freezer is beeping it indicates a warning of a possible malfunction or an unsafe temperature inside. The silence the buzzer, press the ALARM OFF button, however if you have already done so try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. The freezer could possibly be experiencing a communication problem with the temperature control/board or wiring failure.
Nov 10, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
May 25, 2011 | Car Audio & Video
How to set alarm and ring with radio?
Hi gidgid.
This is direct from manual mailed to me from Oregon Scientific re my own contrast problem.
1. Press [ALARM] to switch to display the alarm setting.
2. Select ALARM 1 or ALARM 2 using [ALARM].
3. Press and hold [ALARM] for two seconds.
4. Use VOLUME [ + ] / [ - ] to enter the hours.
5. Press [ALARM].
6. Use VOLUME [ + ] / [ - ] to enter the minutes.
7. Press [ALARM].
8. Use VOLUME [ + ] / [ - ] to select ALARM or RADIO. If
ALARM is selected, a two-minute crescendo alarm will be
emitted at the set time when the alarm is active. If RADIO is
chosen, the radio will be turned on for two hours at the set time
instead.
9. If RADIO is chosen, use [STATION] to choose the radio
station and press [AM / FM] to select AM or FM.
10. Press [ALARM].
11.Use VOLUME [ + ] / [ - ] to set the volume of the wake up radio.
12. Press [ALARM] to exit.
Note: If there is no battery for the radio, there is no operation for
step 9 ~ 11.
sleepy head
Jan 13, 2008 | Oregon Scientific RRM112 Clock Radio
Measuring Tools & Sensors Logo
20 people viewed this question
Top Equity Time USA Measuring Tools & Sensors Experts
Tom Chichester
Are you an Equity Time USA Measuring Tool and Sensor Expert? Answer questions, earn points and help others
