Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
Pc will not start up
I push the power button to turn it on an you have to hold it in and it just keeps flashing and sounds like its going to start but when i let go of the button it goes off. this just happend out of nowhere
  • 2,229 Answers
This could be caused by one of two things:
1) Your power supply has gone bad
2) Your motherboard has a problem.
BUT--to be sure it's one of them, open the case and disconnect the hard drive and the CD. Sometimes they cause problems. Now try to start the machine. If it still won't start, swap out the power supply. It's much cheaper than trying to find a motherboard to swap out. To test it, almost any power supply with the right connectors will work.
Posted on May 21, 2009
  • 3,866 Answers
Replace the power supply unit.. You do not need to have a emachines power supply unit you can buy any third party as now they are all after market..
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
I keep getting the OSD LOCKED that keeps popping up on my screen and it flashes on top of my page and is driving me nuts how do i get it to stop
Are you holding the menu button down when the monitor is off or on? Are you keeping the menu button held down when you push the power button to turn it on?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00748106&cc=us&lc=en&dlc=en&product=3194521#N57...vv
May 18, 2010 | HP Compaq dc7100 PC Desktop
My computer does not turn on easy only lights flash
hmm sounds like your powersupply may be going
Dec 04, 2009 | Computers & Internet
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
Pixma ip 3000 power on all the time no functions. cannon
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
S9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
Nov 02, 2008 | Canon i950 InkJet Photo Printer
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
237 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
