Question about Vivitek V37655 56" DLP TV
Flashing in Blk,Wht, and a little color
I have
  • Jack Richard May 22, 2009
    Thanks for getting back to me with your solution. However, I'm not sure if that's my problem. Have you ever heard the term solarizing. This is the term the repair man told me when he looked at it. I really haven't heard humming as you stated it. The repair man thought it was the DMD board. Do you think I can purchase the DMD board from that part store?
    Thanks,
    Sergeant:
  • 296 Answers
Sounds like maybe your color wheel needs to be replaced. If you have noticed a humming noise in conjunction with the intermittent colors, then that is most likely the issue.
My 51" Vivitek started to hum loudly about 2 months ago and I kind of ignored it ,but it got so loud and annoying I had to do something.First changed the bulb and then bought a color wheel at www.vancebaldwin.com .Login as guest and then enter your model number into corresponding box.They have a few Vivitek parts.
I replaced my color wheel myself and it works great!
I'd be happy to help any way I can.
Posted on May 21, 2009
  • Anjana Batabyal
    Anjana Batabyal May 22, 2009
    Well yes its correct. The DMD board if replaced would resolve the issue.
    I just found out a few weeks ago that you can buy DMD boards and Light Engines from Discount-Merchant.com ..... You might want to look there.. DMD is around $180-$200 and Complete engines are around $300.
    Thank You
Looking for a wiring diagram for a range selector sensor plug for a 2004 chevy silverado 1500,4x4,4.8L with a 4KCD transmission
Connector Part Information • 15416722 BLK
• ASM Conn 12 F GT
Pin Wire Color Circuit No. Function
1 DK GRN 1433 Clutch Start Switch Signal
2-3 -- -- Not Used
4 YEL 772 Transmission Range Switch Signal B
5 BLK/WHT 771 Transmission Range Switch Signal A
6 GRY 773 Transmission Range Switch Signal C
7 BLK/WHT 451 Ground
8 WHT 776 Transmission Range Switch Signal P
9 LT GRN 275 Park Neutral Position Switch Signal
10 GRY 1524 Back-Up Lamp Supply Voltage
11 PNK 839 Ignition 1 Voltage
12 PPL 639 Ignition 1 Voltage
This all I could find, hope it is the correct one.
Apr 08, 2016 | Cars & Trucks
Where is the amp and how do i check it in 98 cadillac
Radio Amplifier
Left hand rear of the passenger compartment, behind the rear seat back.
Check the connections , check power an ground .
12110088
24 Way F Micro-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A1
PPL
1952
RH Front Tweeter Output -
A2
LT GRN
1852
RH Front Tweeter Output +
A3
BLK
1856
LH Front Tweeter Output +
A4
YEL
1956
LH Front Tweeter Output -
A5
DK BLU/WHT
346
Rear Shelf Subwoofer Coil 1 Output +
A6
LT GRN/BLK
1794
Rear Shelf Subwoofer Coil 1 Output -
A7
YEL
1860
Center I/P Midrange Output +
A8
LT BLU
1960
Center I/P Midrange Output -
A9
DK GRN
1795
Rear Shelf Subwoofer Coil 2 Output +
A10
LT BLU/BLK
315
Rear Shelf Subwoofer Coil 2 Output -
A11-A12
Not Used
B1
DK GRN/WHT
368
Right CD Changer Input
B2
BLK/WHT
372
CD Changer Common
B3
BRN/WHT
367
Left CD Changer Input
B4
LT GRN
1948
Right Audio Input -
B5
LT GRN/BLK
512
Right Audio Input +
B6
DK GRN
1947
Left Audio Input -
B7
TAN
511
Left Audio Input +
B8
DK BLU/WHT
653
Chime Input/Return
B9
PPL/WHT
652
Chime Input +
B10
Not Used
B11
PPL
1807
Class 2 Serial Data Line
B12
PPL
1807
Radio Amplifier (UX8) C3
showgif.do?image=35456
12064749
2 Way F Metri-Pack 480 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
651
Ground
B
RED
1242
Battery Positive Voltage (B+)
Check
Mar 22, 2016 | 1998 Cadillac Seville
Where can i get an 01 silhouette pcm pinout
PCM pinout diagrams
2001 silverado (Thanks Banker099)
Try this link for page below
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc1pcm2001.gif
Powertrain Control Module (PCM) C1 (BLU)
• PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
Fuel Injector 3 Control
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
12
DK BLU/WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data [Secondary]
15
DRK BLU/WHT
774
UART Serial Data [Tertiary]
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
21
YEL
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal [- Bank 2 Sensor 1]
25
TAN
413
HO2S Low Reference (Denso Sensors) HO2S Low Signal (Delphi Sensors)
26
TAN
1667
HO2S Low Signal [- Bank 2 Sensor 2]
26
TAN
413
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal [- Bank 1 Sensor 2]
28
TAN
413
29
TAN/WHT
1653
HO2S Low Signal [- Bank 1 Sensor 1]
29
TAN
413
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
33
PPL
420
TCC Brake Switch Signal
34
WHT
776
35
GRA
48
CPP Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRA
720
Low Reference (w/o Delphi HO2S)
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRA
474
5 Volt Reference (FTP Sensor)
46
GRY
474
5 Volt Reference (TPS Sensor)
47
GRY
597
5 Volt Reference (MAP Sensor)
48
GRA
596
5 Volt Reference (EGR Sensor)
49 50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
Not Used
57
ORN
440
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRA
720
Low Reference
63
TAN
413
64
Not Used
65
PPL
1670
HO2S High Signal [- Bank 2 Sensor 2]
66
PPL
1666
HO2S High Signal [- Bank 2 Sensor 1]
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [- Bank 1 Sensor 2]
69
PPL/WHT
1665
HO2S High Signal [- Bank 1 Sensor 1]
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control
80
ORN/BLK
510
Low Reference
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc2pcm2001.gif
May 23, 2014 | 2001 Oldsmobile Silhouette
1992 dodge dynasty radio diagram
Assuming the radio connects to the RS amplifier, the harness is as follows:
From fuse 13: PNK or BLK -> PNK/LT BLU -> PNK or BLK -> PNK/LT BLU -> radio (!)
From fuse 20: RED/WHT -> radio
From fuse 10: VIO -> amp
From radio: ORG and BLK/YEL to interior lights
From radio to amp: DK BLU/RED, BRN/RED, DK BLU/ORG, BRN/ LT BLU, VIO, DK GRN or DK GRN/WHT, DK BLU/WHT, BRN/YEL
From radio to pwr ant: DK RED/GRN
From RS amp to:
R. door: LT BLU/VIO and LT BLU/DK GRN
R. front: ORG/BLK and ORG/RED
R. rear: TAN/BLK, TAN/RED, TAN/DK GRN, and TAN/VIO
L. rear: WHT/DK GRN, WHT/VIO, WHT/BLK, WHT/RED
L. front: YEL/BLK and YEL/RED
L. door: LT GRN/DK GRN and LT GRN/VIO
Mar 17, 2017 | 1992 Dodge Dynasty
Need colour codes for stereo wiring for 2000 hyundai accent
ANT org/wht, LR spkr brn/blk, LF spk blu/blk, RF spk blk/wht, RR spk grn/blk, ILL blk/wht, ACC gry/wht, GRND blk, LF spk brn/wht, RF spk brn, RR spk grn/wht, ILL grn/wht, MEM power org/blk.
Dec 26, 2009 | 2000 Hyundai Accent
Color wireing codes for DEH-P730 cd player
red - acc power
yel- battery power
blk - ground
blu - power antenna out
blu/wht - amp remote out
wht - left front +
wht/blk- left front -
gry- right front +
gry/wht- right front -
grn- left rear +
grn/wht- left rear -
prpl- right rear +
prpl/wht- right rear -
Aug 23, 2009 | iLO CA3000V CD Player
I have a 2000 dodge dakota and i bought a universal h20 sensor and i need to know what the wireing digram for the sensor is the colors on the truck are orange/green and yellow/white and black/blue and...
Ok, the truck - org/grn goes to one of the sensor heater wires (wht).
The truck - blk goes to the other sensor heater (wht).
The truck - blk/blu goes to the sensor ground (grey)
The truck - yllw/wht goes to the sensor signal wire (blk)
Apr 07, 2009 | 2000 Dodge Dakota Quad Cab
Mar 18, 2009 | Vivitek V37655 56" DLP TV
New vr-3 going into used 2004 Status. Current wiring has black connector and grey connector, also one blk/yellow stripe wire. Have wire colors written down, need to know what existing wires are -new radio...
According to www.the12volt.com The color codes for your vehicle are:
RADIO 12V CONSTANT |orange/black
RADIO SWITCH (ACC)|white/black
RADIO ILLUMINATE|green/white
LF SPEAKER|wht/blu - blk/blu
RF SPEAKER|wht/red - blk/red
LR SPEAKER|yel/blu - gry/blu
RR SPEAKER|yel/red - gry/red
Feb 24, 2009 | Clarion VRX935VD Car DVD Player
Vivitek V37655 56" DLP TV Logo
57 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
