Question about Car Audio & Video
I have an Alpine MRP-f450 amplifier, running to four Infinity speakers. One of the channels is intermittent in that sound only comes out of that channel at random times, with long periods of silence in between. I have tried switching the speakers, to make sure it wasn't one of my speakers and all of my speakers work, it is that one specific channel on my amp that is the problem. I have adjusted the fade and balance as well to focus on that channel to see if there is any sound coming out of it at all, and there is, but it is just very low, even at maximum volume. I have tried adjusting the filter settings as well to see if that is a problem, but that did not fix anything. Is there anything else I can try, or do I need to buy a new amplifier?
  • 1 more comment
  • zvergiels May 21, 2009
    Do you mean a loose connection in the amp? I don't think it would be a loose connection or wire outside, due to the fact that I have tried different speakers that I know for sure are working and sound does not come out. Which leads me to believe that that output channel is the source of the problem. All of the inputs into the amp would effect all of the ouput channels as a whole, so this one being the only one screwing up doesn't make much sense to me to think its and input problem.
  • zvergiels May 22, 2009
    How would the components have gotten weak?
  • 1,889 Answers
If you know how to read a schematic, have an oscilloscope and, can solder: and,
If you know how replace the power output transistor on the weak channel then; open the amplifier turn it on connect speakers and, a sound source then apply component cooler to the output transistors and, if the sound comes back replace the transistor that started working again (heat damages transistors) next time put a 12v fan near your amplifier in your car to blow across the heat sink fins to keep it cool and, running a long time.
if not replace the amplifier
Posted on May 22, 2009
    Novelist:
  • 130 Answers
Its the faulty amplifier.its not the wires.its the clear internal circuit board problem as the electrical components have gone weak and so you are getting sound but bit low.
as you mentioned in all the other speaker at that particular connection you are getting bit low volume.this clears that the speakers are not at all faulty.just get the new amplifier and connect the speakers it will work properly.
thanks.please do rate the session.thank you for using fixya.keep updated.
Posted on May 21, 2009
  • 13,433 Answers
Could it be a loose connection or cable?
I have two 12 inch infinity 1250w subwoofers. Will my alpine v-power mrp-m350 amplifier power the subwoofers effectively?
You dont specify the model or RMS power of the subwoofers so i am not sure if that power is RMS or maximum.
If it is RMS, then a BiG no would be the answer. Even though the MRP-M350 will drive the subwoofers and will give you a fair sound as well, it not drive both of them effectivley. After all it's only 350WATT (the amp)RMS trying to push a 2500 RMS (the subs) target, so do the maths, is that a fair fight?
hope this helps.
dreamsystems
Jan 27, 2011 | Alpine MRP-M350 Car Audio Amplifier
I just got the MRP-F300 amp installed today and the rear-left speaker completely stopped working shortly after the installed. There is no cracking, hissing, or any noise whatsoever coming from that...
not usualy if you were running them before without the amp the speaker could have still easily blown. with just the deck running the speakers you can clip the sound and damage the coils hook up and amp then you force the power through an already damaged speaker finishing it off try another speaker. or if it was bought used amp may be no good the previous owner probably noticed it cutting in and out and sold it before it fried. or the deck is old and yes it is a possibility the radio went bad. if you used cheap rca cables yes it could be bad as well.
Apr 08, 2010 | Alpine MRP-F300 Car Audio Amplifier
Can this power a subwoofer and what is the rms wattage
Hello crucible19,
The Alpine MRP-F240 is a 4-channel amp that outputs 40 watts RMS per channel. It is more suited for powering normal speakers, but since it is bridgeable, you could power a small sub by bridging 2 of the channels.
Hope this helps.
Oct 02, 2009 | Alpine MRP-F240 Car Audio Amplifier
My head unit has 1 set of preamp outputs can i conn. 4 speakers
Yes you can use a y to go to all four. Or you could bridge the four speakers wires onto the two outputs for 1 channel
Mar 31, 2009 | Alpine MRP-F320 Car Audio Amplifier
Weak rear left amp output?
hey whats up bud i got an ALPINE V-POWER MRP-M350 these amps are great go to a walmart od any music shop buy a set of R.C.A cables that plug into your amp than that Ys off to a single connection its a male cable that run a set from the back of your cd player heres the trick ONLY PLUG YOUR BLACK COLORED RCA INTO HEAD UNIT MAKE SURE YOU RAP THE RED ONE WITH TAPE OR GET A RUBBER CAP TO PUT OVER IT SO YOU DONT GET ANY STATIC FREQUENCIES COMING OUT OF THE RED ONE THAN RUN THAT SET TO YOUR AMPLIFIER AND AGAIN ONLY TIE INTO THE LEFT CHANNEL OF YOUR AMPLIFIER.... Hope you know wnat i mean by that Y adapter ther is 2 prongs that tie into amplifier than it splits into 1 were your rca cables will plug into just that one thats how you bridge these confusing amps.... TRUST ME BOTH SUBS WILL SLAM HARD I RUN 2 JL AUDIO OFF OF MINE NO PROBLEM.... WRITE BACK TO ME IF YOU HAVE ANY PROBLEMS OR WHEN YOU GET IT HOOKED UP MY EMAIL ADDRESS IS gordo8785@yahoo.com hope to hear from you soon...
Dec 27, 2008 | Alpine MRP-M350 Car Audio Amplifier
Alpine mrp-f300 cuts sound off when volume is turned up.
the problem when someone become a car audio fanatic is, we want to hear BOOMS but we are not sure how many watts the amplifier can handle, besides that theres one very important thing that most of the installers don't know. its called ohms law (not a joke) that law tells you everything about how to measure the ohms marked on the speaker labels and also the way that you connect the speakers (theres two models; serial circuit and parallel circuit)
every single movement that you make on the connections tells a different story, and if you over load the amp it will auto protect.
i suggest you to set the level at least at 60% so you don't make any damage to the internal components, and don't forget to study ohm's law because a really professional installer knows it and well, they do the matt to get the best performance.
Dec 11, 2008 | Alpine MRP-F300 Car Audio Amplifier
Alpine mrp-350 amp
1) If you bridge on a non bridged amp your sound will be horrible as they sine waves comming out of the two teminals will be different... I suggest removing the bridge. 2) The gain knob is to adjust when the amp will reach its max volume with respect to the sterio;s volume. 3) the LP filter is a Low Pass filter and its purpose is to eliminate the higher frequencies that do not sound all the well when played over subwoofers.
Feb 18, 2007 | Alpine MRP-M350 Car Audio Amplifier
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
