Thomson gateway tg728i
I resetted the router manual. After this my router is blinking orange by power button and the ethernet is blinking green too. Nothing other is flashing. I cant use him. Pls help me to correct this. (sry for my bad english)
Verizon
  • 14 Answers
SOURCE: Actiontec (GS503AD3-01) Modem
--If the Power light is flashing red thanits definately problem with the Actiontec Router --As you have checked with different power source, the possibility of bad power source is no more --May be due to some voltage fluctuation the modem is gone bad.
Posted on Jul 11, 2007
  • 30 Answers
SOURCE: Can't login to 192.168.1.1
Hi the username and password for the router has been changed while the previous configuration.If you can call your service providor they should be able to provide the same.There are other some common usernames and passwords which you can try.
username:admin
password:epicrouter
*OR*
username:admin
password:password
*OR*
username:password
password:password
*OR*
username:snowflake
password:password
*******Alternatively you can also try to reset the router to its default settings by pressing the reset button at the back of the router(however this should be the last step of action).
Posted on Apr 13, 2009
frcs68
  • 1605 Answers
SOURCE: need default gateway
try IPconfig/all
usually the defaut gatway is the router own address. i.e. 192.168.0.1 or 192.168.1.1
Posted on May 20, 2009
SOURCE: Cannot reset to factory defaults Thomson TG585
You need press the reset button at least 15 seconds
Posted on Jul 17, 2009
  • 89 Answers
SOURCE: Internet Not Working. Light on box blinks red then green. Gateway
that means the box needs to be reset if its going red like that its glitching if the reset doesn't work then something is wrong and i would get it replaced hope this helps
Posted on Jul 30, 2009
My road runner internet works fine, and for years my linksys srx200 wireless has worked great, just yesterday my wireless connection is excellent as always but our laptops all say cannot connect to the...
Hi
If you have an internet connection using the ethernet cable but not on the wireless and there is an orange light blinking.. Try to reset the router by pressing the reset button located on the back or on the location were you can twist the stand for the router. press it for about 10secs and that will return the router on a factory settings. before u reset the router make sure to acces the configuration for the internet settings of your isp provider. if the orange light still there, try to download the latest firmware of your router on linksys site and that should fix the problem
Jun 10, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
There is an orange "i"
The orange "i" means that the Ethernet cable connection to the modem has been detected.
The light should be blinking green for Internet connectivity.
I advise you to reset the router:
To restore the factory default configuration settings:
1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink .
2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green.
The factory default settings will be restored so that you can access the router from your Web
browser using the factory defaults.
If resetting the router does not correct the issue, you should call your ISP (Internet Provider) and check if they are having a problem.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 23, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Fry's wireless g router
I found this on this site:
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Jan 28, 2010 | 2wire 2700HG-B Router (2700HGB)
Thomson modem problem
Hi there.
The modem needs to be hard reset, on the back or underneath the modem you should find a small hole or button, you need to push this button and keep it pressed in for around 1 - 2 minutes, release the button and give the unit another 2 minutes to settle.
The wireless light should then go green or stay a static orange (not blinking)
If this does not resolve the problem it may need a firmware update.
Good luck
Jun 12, 2009 | Thomson Computers & Internet
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
Connection to my computer of hp photosmart c6300 via belkin adsl2router
3. Open IE beoswer.
Oct 30, 2008 | 2wire 2700HG-B Router (2700HGB)
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Mac and Thompson router
I've run into cable modems that don't like to use ethernet sometimes. In cases like this, I have to do a soft reset of the modem and things usually work again.
To do a soft reset, do the following:
  1. pull the power cord from the modem
  2. count to 5
  3. hold down the power button on the modem
  4. plug back in the power
  5. count to 30 while holding the power button (the modem should be blinking a lot)
  6. release the power button and see what happens.
Jan 14, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Actiontec wireless router
This is a Wireless Gateway not a router. Although the Actiontec website says that it uses NAT firewall like a router would.
If you do not get any green lights this usually means the wireless gateway is broken. Try plugging it into power but not the modem. Wait a few seconds. Are there any green lights?
If so, then the gateway is not configured correctly to work with your modem. You may have a smart modem. Call your ISP, for help.
If not, then it is probably a bad gateway. You can try to connect to the configuration web page that comes with the gateway. OR Power on the unit while holding down the Reset button for a minute. This will reset it to factory defaults.
ActionTec
Nov 20, 2007 | Actiontec (GT704WG) Router
Computers & Internet Logo
David Payne
David Payne
