Question about Yamaha RX-V596 Receiver
Yamaha RX-V596 main rigth channel problem
Recently I've discover that the sound from one of the main speakers has too many static. I've the cords and also plugged the speaker to another channel to check if the problem was from the speaker, but no.
The problem is with the channel output. Can anyone have an idea how to solve this?
  • keyser191 May 22, 2009
    Yes the static occurs on any input source.
    Thanks for the help
    Problem Solver:
  • 3 Answers
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
Posted on May 22, 2009
  • borntobelong May 24, 2009
    Like I said, it may be a bad output circuit. On most amps/receivers the outputs are symetrical, meaning, you can actually view or read values of components on the opposite side of the circuitry, either for reference purposes or in case some components are burnt out you can read the correspondent values out of the surviving circuit side. Note that most surround amps usually have heavier duty amp circuitry for the main channels (left and right) as opposed to the surround outputs which ususally utilize smaller components since the need for power isn't as much for the surround speakers.
    In any instance hope that gives you a north.
    Note.- I have found some amps in the past which have a bad op-amp circuit. which can cause similar problems on only one channel. the op-amp is an IC (integrated circuit) which usually has only 8 legs.
    this is a much simples fix, just swap it with a new one (less than $8.00) and you're done.
    This IC is usually located very close to the output transistors.
    good luck.
I set up my RX-V365 recently, and the center speaker doesnt seem to work. i use it for listening to music, the sound should come out right?
Sound from a speaker, nah, that's an optional feature (kidding).
If you dig into the manual annd go through the setup using the test tones you can prove/disprove the viability of all the speakers and channels. THAT is required before we try to listen to 'music' (assumed 2-channel) on multiple speakers.
Sound Field programs (page 25) can be applied to just about any source. Experiment, even within a given recording. You'll be amazed how different digital processes can make even familiar recordings new and more interesting. I've discovered instruments and sounds in old recording I never noticed before.
Jun 22, 2011 | Yamaha Rx-v365 A/V Home Theater Receiver
My yamaha rx-v596 makes a clicking sound but does not turn on
If it clicks twice almost instantly (on then off within 1/2second) then its got a serious power supply imbalance.
If it clicks on then 5secs later clicks off then one of the amplifier channels has probably failed and the protection circuit is tripping it off to protect itself.
either way its a repair shop job I'm afraid
Jul 16, 2010 | Yamaha RX-V596 Receiver
Can an ipod or mp3 player be hooked to a Yamaha RX-V596, using an auxliary cord
Typically you can find an adapter / cord that contains a 3.5mm headphone plug on one end and a pair of RCA plugs on the other. These RCA plugs should be able to be plugged into any available input on a receiver that isn't a PHONO input. These cables can typically be found online at various different places. Not to promote one site over another, but I have had good luck finding random cables like these at Cableswholesale.com and allelectronics.com. Hope this solves your problem.
Thanks,
Ben
Mar 29, 2010 | Yamaha RX-V596 Receiver
Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
Feb 18, 2010 | Yamaha RX-V596 Receiver
Left channels not working
Check out the left channel amp stages - your issue is there.
Apr 30, 2017 | Yamaha RX-V395 Receiver
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Nov 29, 2008 | Yamaha RX-V596 Receiver
No volume
You need to check the settings and also check the connection from receiver to five speakers .
Oct 28, 2008 | Yamaha AX-596 Amplifier
Hooking up this receiver
I don't see why not. I have a 46" Sony Bravia HDTV that I have hooked up to my RX-V596.
Just use either the RCA out on your TV to the "TV " RCA audio in on the receiver, or if your TV has Optical or Coaxial Audio Out use those...
Dec 27, 2007 | Yamaha RX-V596 Receiver
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
Oct 06, 2007 | Yamaha RX-V596 Receiver
Yamaha RX-V596 Receive turns off after pressing Power
Sometimes the receivers turn off if the speakers are shorted in order to protect the AMP circuit. So try this - 1. Disconnect all cables (speakers), inputs from Tape Deck, VCR and other input devices), sub-woofers, rear speakers all. Except the AC power cord. Then turn it ON and see if it stays on. If it still has the same problem, then most probably your power circuit inside the receiver has a problem - like a shorted Capacitor or diode etc. Based on how technical you can be and what resources and time you want to spend, this is repairable. But based on the price of a receivers these days, it is not worth. Good Luck!
Aug 30, 2007 | Yamaha RX-V596 Receiver
Yamaha RX-V596 Receiver Logo
361 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
