Question about Proform 6.0 CE Rear Drive Elliptical Trainer
Proform 10.0 CE resistance changed
Over period of 1-2 weeks, elliptical resistance changed back and forth, during use, between normal (9) and very difficult. Now have to set level much lower (5) to approximate what used to be normal (9). I do not use the variable programs.
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
I have a Proform Hybrid elyptical/incumbent bike and the resistance levels no longer work .How do I repair this?
Hi There ,
There might be a problem with the resistance motor.
Ring Icon Fitness, they are the distributor for this brand world wide.
Sep 10, 2014 | Proform Hybrid Trainer Elliptical And...
Resistance not adjusting
Reading on HSN website, it is b/c this product is junk. Dozens and dozens of reviews stating the resistance is stuck and wont' change.
http://www.hsn.com/products/proform-smart-strider-spacesaver-elliptical/6647352?query=6647352&isSuggested=True
Jan 20, 2013 | Proform Smart Strider SpaceSaver...
Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
ProForm 675 elliptical is very hard to peddle
use the next steps:
Step 1
Use your flathead screwdriver to pry off the plate on the left side of the elliptical trainer.
Step 2
Look for the magnet and reed switch. These elements will be roughly the same size, and the reed switch should have a series of wires connected to it.
Step 3
Loosen the screw in the reed switch using your screwdriver. Move the reed switch by hand until it sits 1/8 inch from the magnet, then re-tighten the screw.
Step 4
Test the unit to see if the display and heart rate monitor are working properly. If not, move the reed switch slightly so it is closer or farther from the magnet, then try the machine again. Once you've found the correct location for the switch, tighten the screw to hold the reed switch in place.
Step 5
Replace the cover plate by snapping it into position by hand
8_1_2012_1_02_58_pm.gifGod bless you
Jul 31, 2012 | Exercise & Fitness
Proform 405 CE Elliptical display and Silent Magnetic Resistance control stopped working
1) adjust magnet with the bolt looses with a wrench, tight very well.
2) proof the magnet for attraction or repulsion with the magnet from your refrigerator, if NOT pass the test replace it.
God bless you
Jul 24, 2012 | Exercise & Fitness
I have a proform 14.0 ce and the menu buttons dont work
`1) tight the ribblon cable from keypads very well, + tight the wire connector from display board+vs lower board see the block diagrama
2) adjust the reed swithc, clean, and tigh the connector well.
God bless you
Jun 24, 2012 | Proform Pro - Form Rear Elliptical 14.0 CE
My precor efx 546 keypad comes on, the enter button accepts all the info and programs are displayed. 1. The quickstart button does not work. 2. Both crossramp and resistance do not move either when...
1. Sounds like you need a new keypad if some buttons do not work. 2. If those buttons do not work either, it sounds like you need a new keypad, possibly the upper board. Make sure the keypad is plugged into the upper board and the connection is not corroded. 3. Older 546s used an electromagnet to produce resistance, newer 546s use a generator and resistor to produce resistance. I have never seen a 546 that used a motor that moves back and forth to produce resistance. Some residential crosstrainers use a motor like you describe.
Mar 10, 2011 | Precor EFX 546i Elliptical Version 4
I have a proform 390E, and it has a resistance problem, I just checked all the wires and they are connected properly, what should I do now?
Have a 390E elliptical. riding on resistance 4 and then it shut off and went back to resistance 1. now it will not accept any resistance, if you punch in 2 or 3 it registers and then drops back to 1. battery problem? help
Apr 29, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Just bought my Proform 490 LE elliptical 1 day ago and it has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried...
Mar 13, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Proform 6.0 CE Rear Drive Elliptical Trainer Logo
18 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
