1701 HG gateway driver need to find so i can down load
Where do i down load a driver for a 1701HG Gateway
  • Prasanth Prabhakar
    Prasanth Prabhakar May 11, 2010
    Hi is this a modem with wireless feature?
  • 4 Answers
Gateway.com go to support drivers & downloads type in your seail no. and it shoud take you to the download drivers page
Posted on May 21, 2009
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
Lost the set up cd for 2wire 1701 hg gateway. how can I get another one?
I suggest you contact 2wire support here, and ask about getting a replacement. Either that or contact your ISP, who sold you the modem. They may have a replacement available.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 25, 2010 | 2wire 2700HG-B Router (2700HGB)
Wireless hookup (Roku player) to DSL 2WIRE 1701 HG Gateway
make sure to configure the wireless settings of your roku player matching the wireless settings of your router. You need to do manually, go to the network settings of your roku, go to wlan settings and edit the SSID and wireless security key
Jun 28, 2009 | 2wire (1000-400108-001) Router
Broadband yellow light
I'd hate to say this but the 1701 was abandoned and buried a long time ago :( 2Wire was no longer supporting it when Arris bought them out and Arris will just tell you time for a new one. Even electronics with non-moving parts eventually wear out. If you're renting the 1701 time to buy a replacement and save those monthly fees (typical payoff is 10 months or so). Your ISP will have a list of compatible modems, although you might have to deal directly with their customer service to put a new gateway on your line.
Mar 24, 2017 | Computers & Internet
1701hg gateway
you can google your gateway or go to downloadpcdriversupdates.com .
Sep 27, 2008 | Computers & Internet
2 wire 2700 hg-b
The 2Wire 2700 is a residential gateway, a modem and router in-one. There is an RJ-11 jack in the back of the gateway and this is where your dsl phone cord plugs in. There are four RJ-45 jacks in the back for connecting devices using ethernet cable. As a router is can operate both wirelessly and wired. For wireless operation you'll need the WEP key which is located on the tag on the bottom of the gateway. It's the number enclosed in brackets, between the two bar codes.
Redneck Geek
Sep 09, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 1701 HG Gateway wireless not working
There could be a lot of possibilities why you lost your connections at the same time. Could be windows update or changes had been made in your 2wire 2701 HG.Its impossible to say that your wireless adapters turned bad all at the same time.As what you observed , wireless light is off meaning your 2wire doesnt detect any wireless connection. You can try reconnecting them 1 at a time by going to your wireless connection tool or network connections.
If that didnt help, you can use your PC w/c is connected using the USB connection. Using this step, you 'l have a chance to edit and view your wireless network. For you to access your 2wire you must know what your 2wire address {default gateway}. Using your hardwired pc go to start > run > type in cmd then hit enter > on the Dos command screen type in ipconfig and hit enter> youl see your default gateway . It would look like this 192.168.1.254 for example cos sometimes it would vary depending what ISP you have, Open your fav browser and on your address bar type in your default gateway. That would lead you to your 2wire page, there youl have a chnace to view you home network. Check if your wireless encryption and you network name if everything is still the same. {Best thing is to change your wireless name or SSID. Then try to reconnect on your wireless connection for each computer and make sure you have your wireless encryption.
Hope that helps. Pls let me know asap if you need clarifications.
Cheers.
Jun 15, 2008 | Computers & Internet
2wire 1701 hg
If you want to setup wireless network then......
you need to config your router for wireless network..
for that you need to open router configuration page or either you can run the disc you got with your router..
in that it gives you an option of wireless network..
it will ask you to type in a network name ssid give any name you wish to your network..
it will also ask you to type in a password for network...
choose wpa-psk security and type any secure password in 8to 63 charactersand apply and once it's done...
now if you're on windows xp then click start>then control panel>network connections>then rt click wireless network connections and click view available wireless networks there you'll find your network name ssid in it select it and press connect..it will ask for your 8-63 characters password type in the same press connect it will say connected..
unplug ethernet cable and try opening pages ie..
If you're on vista then click start>connect to>rest is same as above...
Feb 12, 2008 | Computers & Internet
2wire Router cannot connect to K Corp KLS-611 adapter 802.11g
if you wantd to change the type of encryption from WEP to WPA...aside from accessing the modem through 192.168.1.254....this ip is used on 2wire1000hg series, 2wire1800hg, 1701hg, 2701hg-b and 2700hg-b
*then you might need to indicate the modem password
*if you know it...indicate so, if not, click on the link that says "I forgot password", it would give you a hint...if you still forgot it, click on "I still forgot password"
*after that you need to click on "home network" which is the icon on the top portion of the page
*then you need to click on "wireless settings"
*under "wireless security" you would be able to change the "authentication", whether it is WEP-OPEN, or WPA-PSK"
- you could also go to: 2wire.com for help, just go to the support section
- or you could also see some simulators if you need one on shasta.2wire.com
Oct 01, 2007 | 2wire HomePortal 1800HG Router...
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
