Question about Refrigerators
Kenmore refrigerator ice making not working
Water keeps running - overflows the tray and into the bin where it freezes
  • Refrigerators Master
  • 4,655 Answers
Need to turn the water off to refrigerator until we find the reason or the ice maker will be damaged. If for some reason the water control valve is stuck open there will be no way to stop the flow other than turning the water supply off before it gets to the control valve. I am here ready to help you, Let me know, Sea Breeze
Posted on May 21, 2009
  • John Tripp
    John Tripp May 22, 2009
    Thank You for your vote. We are here if and when you need us.
  • 10,865 Answers
Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • Posted on May 21, 2009
    My kenmore 106.51133210 refrigerator is not making ice
    Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
    Water Inlet Valve WPW10341320
    If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
    Ice Maker Assembly WPW10251076
    Thank you
    Appliance 911 Sea Breeze
    May 06, 2016 | Kenmore Refrigerators
    Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
    It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
    Before going to buy any parts directly.
    Go through this troubleshooting help links.
    This is list of refrigerator problems, which is normally faced in refrigerator.
    You can go through the details, by clicking the link below:---
    Refrigerator is not cooling properly?
    http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
    Both refrigerator and freezer not cooling properly in refrigerator?
    http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
    The ice maker not working: ---
    http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
    Compressor not running on refrigerator?
    http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
    Water dispenser not working on refrigerator?
    http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
    Ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
    Water Overflows in Ice maker and freezes inside?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
    How to replace Ice maker assembly?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
    These will help.
    Thanks,.
    Dec 22, 2012 | Refrigerators
    Ice maker
    other ice maker related issues and solutions:---
    Ice maker dispensing ice with black or white plastic pieces in ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
    After replacing ice maker assembly, ice is not getting made?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
    Ice maker is leaking water and causing the ice to freeze?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
    Ice maker is noisy and not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
    Refrigerator ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
    Ice maker leaks water into ice bin causing a glob of ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
    Amana Refrigerator leaking water from ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
    Ice maker leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
    Ice maker is dumping the ice cubes out before frozen solid.
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
    Water overflowing ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
    Ice cube is getting stuck up hard in ice maker
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
    Icemaker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
    Quit making ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
    Water leaking into ice tray, frozen glob of ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
    Not making ice, and water leaking in freezer?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
    The ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
    Ice maker not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
    Ice maker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
    Ice maker dispensing black pieces of plastic in the ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
    Replaced Ice maker but its still not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
    Ice maker leaked creating an ice block?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
    Ice tray leaked?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
    Ice maker stopped functioning?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
    Ice maker stop working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
    Ice maker failed
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
    Old ice maker stopped working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
    Old ice maker started leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
    Ice maker not working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
    Ice maker overfills and cause water to flow into ice dispenser and freezes?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
    Ice maker didn't make ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
    Ice maker was leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
    Ice maker was leaking after it filled up with water?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
    These will help.
    Thanks,.
    Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
    Kenmore side by side 2000 refrigerator with water and ice dispenser. The ice does form in the tray but the piece that strips the ice from the tray is missing. I have ordered the piece to replace. The ice...
    Hi, I think you need a new icemaker. What you described seems like water is getting in ice bin with the auger. Either to much water to icemaker and it overflows or if your talking about the rotating strip fingers for the icemaker is missing then yes that is the problem. If ice don't come out of tray and it still cycle it pour water on top of ice and into bin with the auger.
    Sep 08, 2017 | Kenmore Refrigerators
    I am not sure this is the right refrig. I have a model 253.78259800 top freezer with a model JD-21 ice maker. The ice bucket keeps filling up with a solid piece of ice. It makes and drops cubes, then water...
    there s a adjustment but it only controls /like 1 to 2 oz of water . its prbably the ice mker unit or the water valve . .. ice mker tell water how long to let water in and if valve is bak it might not shop off causing water fill . change water valve first . then ice maker if needed .. icemker might have a bad tray and some cubes do not drop / if so next fill will over fill causing problem . mm
    Dec 07, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
    Ice maker stopped making ice. Now water continuously drips.
    Replace the water valve behind refrig , where the wall water line connects to on refrig .
    Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Ice maker overfills and leaks into the ice bin.
    I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
    Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
    Freezer and icemaker freezes, jams.
    I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
    May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
    Ice Maker Overflowing
    i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
    Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
    Refrigerators Logo
    131 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
