Question about Samsung T220HD LCD Monitor
Montor connection I currently have an older monitor. I just purchased a flat screen monitor. What cables will I need to hook this up? I'm pretty useless when it comes to doing this. Monitor is HP,IBM tower. I'm in a wheelchair so i can't get in back. Do i just need 2USB cables, thanks, Mur
  • Murrey Hall May 21, 2009
    Ok thanks, Mur
    Sergeant:
    Novelist:
  • 197 Answers
Your flat screen monitor should have the same connections as your older model, a VGA connection.
Posted on May 21, 2009
Envision en-7500
yYou dont unless you have a dedicated tuner that outputs to DB9 (VGA plug) or HDMI. Older flate screens dont Do HDMI natively so you would have to get a stand alone tuner like this: http://www.google.com/products/catalog?q=VGA+tuner&oe=utf-8&um=1&ie=UTF-8&tbm=shop&cid=16346340210151671120&sa=X&ei=gEiAT9viBuGciQKD3a3AAw&ved=0CFIQ8wIwAA
Apr 07, 2012 | Computers & Internet
Montor blinks white
If this monitor is new return it to the place of purchase, the problem is in the LCD panel display, if out of warranty! cheaper to replace.
Mar 24, 2012 | E-Machines E202 20 inch LCD Monitor
Will my hp pavilion a 420n support a 19" flat screen monitor
I have to assume you are currently using the larger size called a tube type monitor and would like to have an LCD or flat screen type monitor connected to your computer.
To connect to new LCD flat screen monitor to your computer would be exactly the same connection as what you are currently using.
The only problem you could run into is the connector itself. Some of the flat screen LCD monitors do not have the older style connector called VGA, usually blue called DB15, because it has 15 pin connector. They may have only have the newer style called a DVI type. Some do have both types.
Please be sure the LCD you want has the older style DB15 connector to connect to the rear blue VGA input of your compter.
Good Luck
Aug 30, 2011 | HP Pavilion a420n PC Desktop
Trying to hook up my monittor to my hp m480n PC
This should be fairly simple if you have a montor cable 15 pin you can find them at any office supply store like staples or office max.
good luck with it.
Jan 09, 2010 | Smart Modular PYXSCAPE SV1170 17" Flat...
Flatron LCD Montor to a Dell Dimension XPS T500
> out of date?
Are you sure that it is "out of DATE" ???
Reconnect your old monitor.
Set the screen-resolution to 800-by-600 at 60 Hertz.
Shutdown.
Connect the new monitor.
Reboot.
The new monitor will be detected, and will run at 800 by 600 at 60 Hertz.
Change the screen-resolution to some higher value that both the new monitor, and your older video-card, will allow.
Jan 02, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
My montor was working for a day until the screen got black and started to flicker.
Could be a loose connection for power or video. If it is firmly connected to power and PC then it could be the video cable or the video card. Taking it to another PC with another cable is the best way to rule all of this out.
If it still does flickers it could be hardware or firmware in the monitor itself. If your warranty is valid you should contact the vendor.
Who is the manufacturer
Nov 25, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Do i need to do something special to hook my laptop up to a mitsubishi projector using a VGA cable other than fn and f8 on the Dell laptop?
this should be enough to ensure signal is going out of your monitor port on the back of your Dell.
the projectory also supports montor to montor cable rather than vga
suspected for VGA the projector needs to be set to video input
and for monitor to monitor cable to computer input setting.
if picture is not seen straight away cycle FN combination until picuture is seen.
Nov 13, 2009 | Mitsubishi XL5U ColorView Multimedia...
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
The montor doesn't come on and shows no connection on the monitor screen
check the pins on the monitor cable my be some are broken
and also check your VGA card it may not be good and need to be changed
May 11, 2009 | Alienware PC Systems Alienware Aurora High...
Check Signal Cable
there maybe something called source on th screen somewere push that button
Nov 19, 2007 | HP Compaq FP 7317 17" Flat Panel LCD...
Samsung T220HD LCD Monitor Logo
117 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
