Question about Xerox Phaser 8200 Laser Printer
Can I disable the lower print tray?
I have a Xerox Phaser 8200 color printer. It is reporting a paper jam in the lower paper tray. I cannot locate the jam and don't think one exists. Instead I think the connection for the bottom tray was damaged as this used printer was transferred from one office to mine. Can I disable the lower tray in lieu of repair? Please advise,
Thank you,
Lewis
    Novelist:
  • 125 Answers
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
Posted on May 24, 2009
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
Patchy color printing, streaks and dull colors using Phaser 8200
I have the same exact problem. I just switched to a mac and the colors are awful. I tried from 3 different macs at work, trying different combinations of color profiles, settings, etc, and the colors always look completely off. Blues are magenta, bright red is a dull reddish, orange is completely brown. It looks like Xerox decided to not even try to make this aspect work with the Mac. This is on the latest Mac book Pro, running Snow Leopard, to a Xerox Phaser 8560 DN.
Jan 05, 2010 | Xerox Phaser 8200 Laser Printer
XEROX 8200 PAPER JAMMING
SOund more to me like you have worn out feed wheels. They are slipping when trying to feed, therefore you get a paper jam indication, but no paper has been fed. Check the feed roller texture. If it is slick replace the roller.
I will state that first. You could have a sticking sensor, but that is less likely if you say it feeds paper.
The second most likely problem is the paper feed or paper registration clutch failing. Those are electromechanical clutches that are located on the loerf front section of the frame. You would need to remove the left side cover ( looking from the front). The clutches are round and silver, about an inch and a half thick with black gears on them. If the clutch faces are slipping, the rolllers will not drive and result in a jam.
The more I think about what your describing, the more I believe one of your clutches is bad.
Sep 26, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200
Have you loaded both trays? The bottom tray and the upper tray ? The one that folds into the machine. Something may be trying to run from tray 1. Upper tray
Jul 17, 2008 | Xerox Phaser 8200 Laser Printer
Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Apr 02, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Sep 07, 2007 | Xerox Phaser 8500/DN Printer
Phaser 8200
Not a problem, but turning it off causes the machine to do a setup, which then purges the ink supply and is very wastful.
Mar 21, 2007 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
468 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
