Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Won't start I hava a Poulan model 2000 16" saw. It won't start. I found the fuel line broken and replaced it. Now I see fuel in the line but still won't start. Wanted to look at the spark plug. Pulled the boot off,a bare wire remains coiled around the plug but I can't see how the cable was making contact with the plug. Perhaps I need a new cable?
  • Lang S
    Lang S May 22, 2009
    OK, I have done as you suggested, including putting in a new spark plug. However it still doesn't start. Any more ideas?
  • Lang S
    Lang S May 22, 2009
    I fooled around a bit with choke, no choke, throttle, no throttle etc and finally it started! I'm not sure but I think it started when I didn't have it choked. I used it for several hours. It does stall frequently but I could always restart it. Should I try to up the idle speed to prevent stalling?
    Thanks for your help Dwain.
    Lang
  • 376 Answers
The cable is part of the ignition coil. The 'bare' wire you saw is the spark plug terminal that has a right angle bend in the end that sticks into the cable. You pulled it out trying to remove the cable off the plug, Those kind of connectors fit tightly and it is better to pry up on the bottom of the boot when removing plug wire. Pull the coiled wire connector off the plug, slide the boot back and with pair of pliers, squeeze the connector back into the cable, in a different spot. Slide the boot back and put it back on the plug.
Posted on May 22, 2009
  • Dwain Pippen May 22, 2009
    First I would remove the plug (carefully, lol) and blow out the cylinder to make sure it wasn't flooded. Replace plug and squirt a small amount of fuel directly in the carb. If it starts for a second and dies, I would replace the carb. Give that a try and let me know.. Dwain
  • Dwain Pippen May 23, 2009
    I'm not sure when it stalls, but if it's when you first give it gas, try turning the adjustment screw nearest the engine counterclockwise about 1/4 to 1/2 turn (or more) while 'goosing' the throttle to see if it revs up any better.
Saw is a 14 inch model 1950. Saw starts but won't run
Check the fuel filter, air filter and muffler for plugging. Make sure the carburetor fasteners are tight. Does the primer bulb fill with fuel after several pumps? Hope this helps!
May 12, 2010 | Poulan 14" Chainsaw
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
Fuel line routing
A typical fuel system and a couple of suggestions follow:
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
I need to replace all of the gas lines. Do I have
There is no reason to disassemble your saw, Please stop.
You can find a typical fuel system and a couple of suggestions here:
An IPL for a Poulan “PP3816 Gas Saw Type 2” can be found here - There are slightly different models. Please ensure this applies to your saw:
http://www.ordertree.com/modelinfo/PWE/PP3816-Gas-Saw-Type-2/75.PP3816-Gas-Saw-Type-2.1.59.1.html
The small hose goes between the filter and carburetor and from the IPL the carburetor and primer.
The large hose between the primer and fuel tank (return).
If the above is not the correct model it can be found here:
Poulan.com
Hose can be purchased at any chainsaw outlet, Inquire about how much hose they recommend. I have not found a good hose stretcher and I have been looking. Good luck with your project. Any additional questions you may have can be asked below. I hope you found this most helpful.
Lou
Jan 31, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan chainsaw repair manual or routing new fuel lines, deterriorated from E10 use.
What you request to the best of my knowledge does not exist. You may find this helpful. Had you provided a model and serial number it would have been more helpful.
Typical fuel system and couple of suggestions:
The IPL for you saw can be found here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
If I can be of further assistance you can reply below. I hope you found this most helpful.
Lou
Jan 30, 2010 | Poulan Garden
I have a poulan pro 210 chainsaw both fuel lines has rotted off standing behind the saw to the right of the carb there is a large hole in the tank to the left there is a smaller hole, it has a primer bulb...
This should help:
This too:
Poulan.com
I think this is your saw please ensure I am correct.
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
If not your saw it can be found here:
The dash number of your serial number is the type. HTH
Lou
Take some pics first then a small sample of the different fuel lines to your local chainsaw seller. A little extra is agood idea, I have not found a good fuel line stretcher and I have been looking. Probably a good idea to replace the fuel filter too.
Jan 16, 2010 | Poulan Garden
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas line
What little fuel system detail ther is can be found here:
Poulan.com
Find a model number that matches your saw.
Fuel lines run from the tank to the carburetor to the purge pump and back to the tank. Take extensive notes and a few digital photos as you go are a good idea.
SmallEng.com
HTH
Lou
Oct 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Have craftsman chain saw, runs ok for a few minutes then dies. found broken gas line.replaced fuel line,air filter,spark plug, checked muffler, also mixed fresh gas.eng acts like its out of gas. leave it...
The plugged vent gets my vote. Loosen the fuel cap when it starts to starve.
All Poulan IPLs (exploded parts list) are here:
Poulan.com
Find your model, what little fuel system detail there is can be found on it. HTH
Lou
Oct 04, 2009 | Garden
I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
240 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
