Question about Toshiba Satellite A215-S7422 Notebook
TOSHIBA SATELITE 215 NOTEBOOK HEATS UP.
My notbeook starts heating up about 15 min after I turn it on. The fan seems to be working right but the air that comes out of the fan is really hot as I said after about 15 min after turning it on. Actually it shutted automatically off once.
Hope I can find a solution for this.
Thanks!
    Problem Solver:
  • 15 Answers
One quick and easy fix you can do is to go get a can of compressed air and blow out the vents and fan area under the notebook. Sometime when there is a lot of dust in them they overheat pretty quickly and shut off. Just like you said happens.
Posted on May 21, 2009
I love my notebook but all of a sudden its shuts down because it continues to get hot underneath and its not the battery..I log on and it may last 15 mins maybe 45min at the most...what is going on? I
COMPUTER/LAPTOP OVERHEATING
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.http://www.fixya.com/support/r5959377-overheating_computer
Jan 13, 2012 | Toshiba Satellite L455D-S5976 Notebook
Hello, I have Toshiba Satellite M200 window Vista, I have a new problem after working for 10-15 mins my laptop is getting hang nothing visible on screen just blurred screen , when i switch off and start...
Your Toshiba could be overheating.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
Jul 06, 2011 | Computers & Internet
Weird problem, 2005 Kia Spectra5, after air conditioning or defrost is running for about 15-20 mins, seems like the air stops blowing, even though the fan is running, turn the heat settings to fan for...
you may want to check and see if the cycling switch is defective...it engages and disengages the clutch on the compressor ..i would check and see if the clutch stops engaging when the a/c starts blowing warm
Feb 08, 2011 | Air Conditioning and Heat for Kia Spectra5
Suddenly shutting off power sometime beeping
there was a problem with notebook overheating and it would be fixed by cleaning the cooling component ,check the heat sink and the fan. The notebook processor produces a lot of heat when the notebook is turned on you check
If the fan working fine, then check if the heatsink is clogged. In some cases you can clean the heat sink with compressed air,
Thanks,
Dec 23, 2009 | Toshiba Satellite M35X-S349 Notebook
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heats for 15 - 20 mins then blows cool air
If the outdoor unit is in defrost mode the compressor will be running but the outdoor fan will not. You may even see some steam rising from the coils. This mode is to prevent frost or ice build up on the outdoor coil. Essentially it goes into cooling mode w/o the outdoor fan running.
Mar 05, 2009 | Goodman GPC1342H21A Air Conditioner
Satelittle A75-S229 shut off
This is a oh-so-common problem for the Satelite A70/75 and it usually is caused by one of two things. If you google "Toshiba Satelite heatsink overheating" and/or "Toshiba Satelite DC plug" you will get a very extensive list of options to repair the problem.
This should take care of the problem and if it doesn't please let me know - it will mean I have something new to look forward to!
MJA
Aug 27, 2008 | Toshiba Satellite A75-S229 Notebook
Laptop (Toshiba Satelite A60) keeps turning off
Is it turning off by itself after being on for 20min... each time? I.e. is it consistently turning itself off after the same amount of run time? Check the bottom of the laptop... how hot is it? Might be an over-heating problem. Some freeware (MobileMeter) might help you monitor temperatures and see if it is a problem
MobileMeter
http://www.softpedia.com/get/System/System-Info/MobileMeter.shtml
Some excellent heat management information here:
http://www.technowledgebase.com/2007/07/03/monitoring-your-laptops-temperature/
Jul 05, 2008 | Toshiba Satellite A60 Notebook
My satelite a100 laptop overheats and shuts down
Your cpu cooling fan may need to be replaced.
Apr 17, 2008 | Computers & Internet
Laptop wont turn on at all!
Over heating can cause a computer not to turn on, or turn off after a period of time.  You might have some dirt and dust in your fan that you need to blow out with canned air.
You might also try a laptop cooling plate:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2427205&CatId=215
Oct 14, 2007 | Acer Aspire 3000 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
