Question about Euro-Pro 373 Mechanical Sewing Machine
How to thread
How do I thread machine
Why does bobbin make thread bunch up
Thread tension is incorrect. See the links
Incorrect thread tension - Brother Solutions Center
support.brother.com/g/b/faqend.aspx?c=au&lang=en&prod=hf_ns55eas...
Jul 30, 2014 - Turn the thread tension dial to select an appropriate thread tension. The appropriate thread tension differs according to the type of fabric and thread being used. ... If the upper threading and lower threading are incorrect, the thread tension cannot be adjusted correctly, even by turning the thread tension dial.
Sewing Lesson 10: How to Fix Tension on Your Sewing Machine - Oh ...
ohyoucraftygal.blogspot.com/2013/10/sewing-lesson-10-how-to-fix-tension-on.html Incorrectly threaded machine: Did you use all thread guides? Did you thread with the presser foot down,which would keep the thread from slipping fully between tension discs? Is thread unwinding freely from the spool, or catching on the spool's slash? Are you using a bobbin as a spool (which can interfere with the thread ...
Understanding Thread Tension on Your Sewing Machine - Threads
www.threadsmagazine.com/2008/11/02/understanding-thread-tension Nov 2, 2008 - When the bobbin thread shows on the right side, the needle tension is too tight or the bobbin thread, too loose, as shown in the middle drawing at right. When the needle thread shows on the wrong side, the needle tension is too loose or the bobbin thread, too tight, as shown in the bottom drawing at right.
Correct vs Incorrect Tension: Your Tension Troubleshooting Guide
www.sewingreviews.org/correct-vs-incorrect-tension-your-tension-troubleshooting-gu... I've seen many sewers make the mistake of using the same tension setting for all their sewing projects and then they wonder why the finish isn't perfect. The fact is, the wrong tension is a sewing disaster. It can ruin your sewing project and literally give you a tension headache. Knowing how to troubleshoot your tension ...
Sewing Machine Thread Tension - Updated - YouTube
? 8:51
https://www.youtube.com/watch?v=sf6oPMbLPzo Jul 12, 2016 - Uploaded by Professor Pincushion
Learn how to correct thread tension so that your stitches come out perfect no matter the type of fabric you're ...
Thread Tension - The Sewing Directory
https://www.thesewingdirectory.co.uk/thread-tension/ When sewing fabrics together problems can occur when the thread tension is not correct, the needle or bobbin is not inserted properly, or the machine is not threaded correctly. Threading instructions for sewing machines and overlockers are included in the machine's manual and should be consulted before you start sewing ...
Incorrect thread tension ' Brother CE1100PRW User Manual ' Page 89 ...
www.manualsdir.com > Brands > Brother manuals > Sewing machines > CE1100PRW Brother CE1100PRW User Manual • Incorrect thread tension • Brother Sewing machines.
images for Thread tension is incorrect.
More images for Thread tension is incorrect.Report images
How to Adjust the Tension on a Sewing Machine: 13 Steps
https://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
Apr 08, 2018 | Sewing Machines
How to thread a bobber model SE 200JjoAnnSewEssential sewing Machine
The thread will now go downward on the left side of the take-up lever.
  1. Locate and thread any thread guides, leading down to the sewing machine needle.
  2. Thread the sewing machine needle. Hold the thread with your left hand and turn the hand wheel.
  3. Watch for any thread to flap around.
Step-by-Step Guide to Threading a Sewing Machine - The Spruce.
or go to this link. How to thread bobbin Essential sewing Machine Google Search
Oct 26, 2017 | Sewing Machines
Serger machine not braiding
Remove all the threads from the machine.
Be sure, when you thread the machine, you ALWAYS RAISE the presser foot. Also when threading from the thread tree down through the tension disk, give each thread an extra little tug to make sure it is seated.
Always thread each thread in the order specified. Threading out of order will guarantee failure. If a thread breaks, start over with no thread in the machine.
Jul 27, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
Why does my machine break the thread a lot? A juki cp 130
tension too tight or incorrect threading, or bad thread.
Mar 13, 2017 | Juki Sewing Machines
I need to know how to thread a empisal purdy 444 sewing machine
Most machines thread basically the same.
Thread spool
Thread guide
Thread guide
Tension
Take up lever
Thread guide
Thread guide
Needle.
There may be an extra or one less of the guides but for the most part I've been able to thread any machine.
Good luck and god bless
Angela
Sep 11, 2016 | Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
How to thread the machine
Hello
Place spool of thread on the spool pin, found inside the carrying handle on the top right side of the machine facing the back.
Lead thread through the upper thread guide, located just beyond the machine's handle.
Lead thread through the second upper thread guide, found a few spaces to the left of the first upper thread guide mentioned in Step 2.
Bring thread around the second upper thread guide down into the thread guide.
Lead thread toward you down through the tension discs.
Continue to pull thread down through the ****. Forming a "U" shape, bring thread back up the left side of the guide, catching the check spring as the thread moves back up through the guide on the left side.
Bring thread up to the take-up lever and insert thread through the eye of the lever in a right-to-left motion.
Lead thread downwards, slipping it down through the horizontal thread guide.
Guide thread through the wire thread guide that is attached to the needle clamp.
Insert thread through needle from front to back, pulling thread four to six inches to create a thread extension. The machine is now threaded.
Aug 01, 2011 | Euro-Pro Shark Mini Mechanical Sewing...
How do i thread this machine
thread this machine by taking a strain of thread from the spool pull it to the thread guide on top left side of machine criss cross the thread when you wrap it around the thread guide pull thread down and loop it under the needle thread tension control dial bring thread up and loop it on the thread take up lever, continue down to the needle looping it first around the metal piece above it then through the needle it self pull thread to back of sewing manchine with the bobbin thread
Feb 12, 2009 | Brother LS-1217 Mechanical Sewing Machine
Euro-Pro 373 Mechanical Sewing Machine Logo
71 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
