Question about Oster 4094 Designer Classic Beehive Work Top Blender
Fuse amperage on Oster Blender 9094
The fuse blew on my Oster 9094 blender. Fuse has .8A stamped on end case, I don't think this is a .8A fuse. I replaced fuse and it blew on start up. Info on bottom of blender says 500W and 120V. This would indicate a fuse rating of 4.2A. Oster refused to tell me what the fuse size is for this blender.
Can you provide this information?
Thanks,
spurs21
  • 26 Answers
SOURCE: blender problem
Yes there is, however unless you are very mechinal incline I won't suggest that you try to replace the defective terminal fuse. This is cause by running your blender continuous. Let me know if you are welling to do the repairs yourself, so that I can give you the directions. Sign, Spurs21
Posted on Jun 12, 2007
SOURCE: top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Posted on Jan 20, 2008
SOURCE: How do I replace the fuse on my Oster Blender?
I have the same problem. Where did you buy the fuse from?
Posted on Jan 26, 2008
SOURCE: Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Posted on Feb 01, 2009
bunnydawg
  • 5158 Answers
SOURCE: HOW DO I REPLACE THE FUSE ON AN OSTER BLENDER MODEL 4094
unplug it.... use a small plastic screw driver or even a metal one if you are careful... pry gently up on one side of the fuse... it should pop out of the holder. when it does... use your fingers to grab the end and pull up. the fuse is replaced by placing it back into the holder and pushing down until each end pops back into the holder
Posted on Apr 11, 2009
Need a replacement jar
  • VillaWare V001-43100 Pro Infinity Blender - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16896115006
    • 2/5
    • 2 REVIEWS
    Buy VillaWare V001-43100 Pro Infinity Blender with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Oster® Blender Parts: Find by Model ' Oster® Canada https://www.oster.ca/en_CA/parts-and-accessories/blenders Pick your model and see all of the blender replacement parts available on Oster.ca.
  • VillaWare V001-43100 Pro Infinity Blender Overview - CNET www.cnet.com > Appliances > Small Appliances VillaWare V001-43100 Pro Infinity Blender overview and full product specs on CNET.
  • Model #43100 Need a plastic Jar replacement. Where can I ... www.fixya.com > Forum > Blenders Model #43100 Need a plastic Jar replacement. Where can I find one. Where can I get replacement parts - Blenders question
  • Tilia 1000W Moderno Blender ' TheFactoryDepot thefactorydepot.com/Tilia-1000W-Moderno-Blender/M/B000GFG2W4.htm Tilia 1000W Moderno Blender: MODEL- V001-43100 VENDOR- VILLAWARE FEATURES- Moderno Pro I
  • VillaWare V001-43100 Moderno Pro Infinity Blender - 67 Oz ... www.tigerdirect.com > Appliances - > Blenders - VillaWare V001-43100 Moderno Pro Infinity Blender - 67 Oz, 1000W, Speed Setting Dial Item#: YYD1-V43100 ' Model#: V001-43100
  • Oster Blender/Mixer Parts ' Reliable Parts https://www.reliableparts.ca/catalog/592809 You Are Here: Home > Small Appliances, Parts & Accessories > Oster Blender/Mixer Parts A selection of Oster ... Search by Model of Appliance:
  • Amazon.com: Customer Reviews: VillaWare V001-43100 Pro ... www.amazon.com/VillaWare-V001-43100-Pro-Infinity-Blender/product... Find helpful customer reviews and review ratings for VillaWare V001-43100 Pro Infinity Blender at Amazon.com. Read honest and unbiased product reviews from our users./>
  • Parts for the Blender at VillaWare.com. www.villaware.com/parts/parts-by-model/parts-for-the-villaware... Shop the Parts for the Blender at VillaWare.com. Food, Passion, Life.
  • http://www.bing.com/search?q=blender+Model+43100+parts&qs=n&form=QBRE&pq=blender+model+43100+parts&sc=0-25&sp=-1&sk=&cvid=F6D21CC73446407E940EA71DFB37D5F2
    May 20, 2016 | Blenders
    Burnt smell on oster blender
    If you have eelctric knowledge, disassemble the case and look for some corroded contact or cable.
    You can follow some of these youtube tutorials or look for additional info by doing a Google search using terms
    Youtube disassemble blender
    iFixit Blendtec Total Blender Disassembly
    How to open and repair Braun Hand Blender Part1
    KitchenAid Blender Coupler Repair KSB5 Model
    OSTER Blender Repair How to fix an broken driver
    If you are not familiar with disassembling a blender but you feel you have the knowledge to do it, take a photo of each step so when you have repaired the problem, you should have no problem to reassemble it again
    Sep 04, 2013 | Blenders
    Blender 6812 does not start at all
    Flip it upside down and take the bottom off and look for a fuse.
    Nov 06, 2009 | Oster Blenders
    Fuse blew on my Oster BCVBO7 blender. Can it be
    replace the fuse with the same specs. if it blows again, there is a short on the circuit.
    Aug 22, 2009 | Blenders
    Apr 11, 2009 | Oster 4093-8 Osterizer Classic Blender...
    Lost blender fuse
    There are no service manuals available for this model. If you can figure out what fuse it takes, Radio Shack most likely has them. What are the specifics?
    volts
    amps
    watts
    It can be figure with the electrical information. You will still have to get the right physical size though.
    Feb 12, 2009 | Oster 6854 14 Speed Blender
    Help me revive my dead Oster blender
    Check the motor brushes. They may be worn out. Also, since the 1980s, many electric motors have a thermal fuse in them. This unit "blows" when it gets to a certain temperature.
    This fuse looks like a 22-caliber bullet and its pointed end is usually colored. If you have an ohmmeter or continuity checker, see if current will pass through the fuse. If not, you can try to replace it. Most times, the fuse is attached with crimp-on connectors. Replacements can be soldered in, if you put a clip-on heat sink between the fuse body and the soldering iron.
    Mar 09, 2008 | Oster 6854 14 Speed Blender
    I just had the same problem too and ordered the fuse online with the link above. Thanks lele44!
    The four feet on the bottom are easily removed with a 1/4" socket slipped inside the each rubber foot fitting.
    I'm glad I found you. I saw some downright horrible reviews of my local Oster appliance service center here:
    http://www.insiderpages.com/b/3723327730
    Rob
    Sep 17, 2007 | Oster 4134 / 4126 Classic Beehive Work Top...
    Oster 4094 Designer Classic Beehive Work Top Blender Logo
    160 people viewed this question
    Top Oster Blenders Experts
    Dan Webster
    Dan Webster
    Dave
    Dave
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you an Oster Blender Expert? Answer questions, earn points and help others
