Question about New Home 2014LE Mechanical Sewing Machine
How to oil my new home 2014LE machine - New Home 2014LE Mechanical Sewing Machine
What size bobbin?
Contact your local Janome dealer. They most likely carry the bobbin you need.
Sep 13, 2016 | New Home 2014LE Mechanical Sewing Machine
What size light bulb does this machine need?
here is a link , check with them and see if they can help you with the part you need
http://www.sewingmachineoutlet.com/newhome2014.htm
Oct 01, 2013 | New Home 2014LE Mechanical Sewing Machine
Bobbin thread not sewing tight
try adjusting the top thread tension one number or letter higher
sewing on a scrap piece of fabric till the stitch looks normal.
Jan 17, 2013 | New Home 2014LE Mechanical Sewing Machine
New Home Model NH 2014lLE. Stopped working
something is jammed further then you can see. stop. be patient here. if unplugging and plugging it back on does not fix. just take a deep breath, you do not want it to break. its just a machine. i would suggest taking it to a shop to see if they can clear your jam by an adjustment, for free at your local store. or a tune up of $50.00 bucks . this machine is well worth it! its a bizarre thing that has happened, but to force it you could really hurt it more then you know.
Jul 13, 2010 | New Home 2014LE Mechanical Sewing Machine
The top thread keeps breaking off on my NH 2014 LE
i have the same machine, what do you mean the top thread is breaking off? exactly where do you see it breaking off. is your tension soo tight that it breaks? is your thread soo old that it breaks? explain a bit more.
Jun 18, 2010 | New Home 2014LE Mechanical Sewing Machine
Threading a bobbin on the new home 2014le
place spool of thread in , route it towards your bobbin holder, take thread and put through one hole about 4 inches hanging ontop. press it in and slide it to the right where you hear a click, hit the peddle, should be winding, it will automatically stop on its own when full. click it to the left when done, snip it and then drop that into your bobbin holder , cover your plate, thread your upper thread and presto you are now sewing with your threaded bobbin, always remember these steps. #1 material choice #2 thread weight #3 needle size. you got to match those 3 for beautiful perfect stitches.
Dec 16, 2009 | New Home 2014LE Mechanical Sewing Machine
Material will not feed across pressure plate of my new home model sx 2122 sewing machine
This machine has a pressure regulator on the left side.You should look to see that it is not loosened. When you lift up on the presser foot it should have resistance.
Then look at the feed dogs to see that they are moving, Set the stitch length at 4 and turn the hand wheel. The teeth should move towards the back of the machine. They should also be slightly above the needle plate as they go back and below the surface of the plate as they come forward.
If they don't rise above the plate , remove the needle plate and clean between the slots of the teeth.
sewman7
Jul 01, 2008 | New Home 2014LE Mechanical Sewing Machine
New Home 2014LE Mechanical Sewing Machine Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
navapistol
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
