Question about Motorola Mobility DCH3416 (160 GB) DTV Receiver Video Recorder
Eas code Won't allow the cable to come on
Heater won't turn off. Error message on display panel says "c". Heater blowing on High.
Disconnect neg / grnd battery cable. Replace Heater Blower Resistor. This will allow the heater blower to operate correctly
Mar 03, 2013 | 1989 Cadillac Sedan DeVille
Won't connect to router
Shut down compter, unplug router and the ISP modem, Check ALL cables and reseat ALL connections, plug in the ISP modem allow it to selftest, plug in the router allow it to selftest. Reboot the computer, plug in Ethernet cable.You didn't give much info to work with. Wired? Wireless? Does it connect to other devices? What is the OS? Vista? Is this a recent issue? What it the router Make ,Model? Open the Network and Sharing Center, Manage Network Connections, Is the Ethernet Adapter enabled?
Jan 07, 2013 | eMachines ET1161-03 PC Desktop
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
Shift cable fix car still won,t start
Sounds like you may have an adjustment problem with the cable. There is an Interlock feature which keeps you from starting your car in gear.
In a nutshell, your car does not know it is in Park or Neutral- the 2 modes which allow the starter to work. You need to adjust the length of the cable to finetune the Lockout. Some cars also require a foot on the brake pedal to allow for starting and these 2 switches work together so that your car can not be started in gear or without a foot on the brake(some models).
Jun 07, 2012 | Cars & Trucks
Shift cable won't stay attached to transmission
As far as the shifter cable not staying attached to the ******, (AT), My solution was to shave the plastic end thinner so it will go further on the shifter rod. This will allow room for a washer and cotter pin to be attached to the rod. (holding the shifter cable in place. It's easier to remove the shifter arm as you will need to drill a small hole for the cotter pin. This is the cheapest solution that works. The shifter cable is over $40 and a headache to install. Hope this helps.
Aug 12, 2011 | 1994 Pontiac Firebird
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
New cable box now can't get panasonic DMR-EZ475V to work!
Do the first time setup and when it asks how you receive the rf signal select no as the answer, this will allow you to record directly from your cable box but you won`t be able to record and watch another channel.
May 29, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Motorola Mobility DCH3416 (160 GB) DTV Receiver  Video Recorder Logo
18 people viewed this question
Top Motorola Mobility Televison & Video Experts
Are you a Motorola Mobility Televison and Video Expert? Answer questions, earn points and help others
