Question about 1999 VW Beetle Strut & Spring Front Driver or Passenger Side
I change the shocks, balljoints, control arm bushings and the tie rod ends and still makes noise like something is loose and it still feels like if it had bad shocks what could that be?
Feels and sounds like something is loose in front suspention
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Did you replace all rubber parts???
Posted on Oct 09, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
My 2000 Concord is still making a bang from passenger front Just changed half shaft , rotor , caliper and pads Is it the ball joints ? Bangs when i stop
jack up and support vehicle grab top and bottom of wheel and see if its loose if loose feeling up top or clunking possible upper ball joint if bottom feel/noise poss bottom ----move wheel side to side and look and check tie rods if loose or noise inspect and replace if damaged or worn ---remove wheel and inspect the joints and tie rods if their was no noise or worn check the upper and lower control arm bushings as well as the swaybar supports and bushings
May 18, 2016 | Cars & Trucks
My front axle is rubbing and tearing my boot why
Do you mean the tie rod end? Did you recently change your tires and/or wheels? Wheels can have different offsets, so choose carefully if you change them. I had problems with my track bar on mine. It was wrecked before though. Has yours suffered front end damage that you know of? Have someone watch underneath while to turn your wheels back and forth slowly. They should look for anything shifting or separating.
Aug 09, 2015 | 2004 Ford F150
I have an 03 chevy s10 pick up. 2wd. When I turn the steering wheel 1/3 of an inch it sounds like a knock or something is loose. Also my tire makes a weird loose sound when driving. Any idea on what it can...
Bad wheel bearing/ ball joints/ tie rods
If lugs on wheel r tight
Could b control arm bushings also
Can b many different things..
Jack car up and give wheel a shake side to side..get play then tie rod most likely
Up and down play then most likely balljoint
Both then either both or wheel bearing
Wheel bearing will have the same amount of play in each direction
If u get some strange play then look at control arm and checkh for playe
Sep 02, 2014 | Cars & Trucks
I have 2004 ford freestar it makes a poping noise as u drive changed cv joint don't know what else it might be
lots of things can make it "pop". check the hub bearings, the stabilizer links, the tie rod ends, the balljoints, the struts and strut mounts, the engine cradle bushings, the control arm bushings ,and the engine mounts. GOOD LUCK!
Jun 14, 2012 | 2004 Ford Freestar
Makes a funny noise when i go over a speed bump chevy 2001 mal
what sort of noise clunks&bangs could be anything from shock mounting bushes exhaust hanging mounts or suspsion bushes.it would be a good idear 2 have a mechanic put it up on a hoist 2 check it out
Sep 10, 2011 | 2001 Chevrolet Malibu
Rattling/clattering from suspension on poor roads
check shock absorber mounting support/ must be worn-out/ or stabilizer bar rubber bush / or stabilizer linkage rubber bush/ check tie rod ends balljoints / check lower suspension arms balljoints as well as upper suspension arm balljoints and lastly check strut bar rubber bushes/ all the mentioned parts can be easily seen underneath the car....
Apr 09, 2010 | 2003 Land Rover Range Rover
Front end feels loose and steering wheel shakes after going over rough terrain... what could it be.
Tie rod ends or ball joints. Possibly a control arm bushing failure but not as likely. Could also be caused by worn out shocks but usually that causes the truck to bounce up and down after hitting a bump.
Sep 24, 2009 | 1998 Ford F150 Regular Cab
I feel a slight thud in the steering and hear a light thud when I turn a corner; seems to happen most when the car has just started driving; is this an issue of power steering fluids, something in the rack...
This is most likely the steering knuckle or tie rod end that needs grease or most likley replacement. If your hear clunk when turning, then it is proabably the tie rod ends. If clunks while driving, then it may be the balljoints.
Sep 10, 2009 | 2001 Volkswagen Passat
1999 VW Beetle Strut & Spring Front Driver or Passenger Side Logo
66 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
