Can't turn off timer on Fujitsu heater - Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
How to turn off the timer on the Fujitsu AC Model AR-RAC3E?
Hi Rismita,
I hope the following link is helpful for you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 18, 2015 | Fujitsu Heating & Cooling
Timer light on fujitsu heat pump flashes not heating
the light flashing indicates there is a problem. you can try reseting the system by turning the power supply off and back on again 30 sec later, if the same thing happens you need to count the number of light flashers and that relates to a fault code
Jun 20, 2012 | Fujitsu Heating & Cooling
Could you please advise how to reset lamp timer on a fujitsu LPF 4800 when I turn it on the green light goes to red and the lamp light indicator goes to red too and blinks
hi
You can reset the lamb timer as follows.
While pressing the MODE button, press the POWER button three times.
all the monitors flashes for a few second , The lamp timer is initialized to[ 0 hours] .
ok
Dec 15, 2010 | Fujitsu LPF 4800 Multimedia Projector
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
Timer
turn the unit off, replace the battieries in the remote
power the unit on with the remote. On the remote see if there is a systedm reset and if there is reset it.
Jul 03, 2010 | Fujitsu 24C1 Air Conditioner
Heater not working
Model ASTA24LCC found that the problem was the valve inside the out door unit that reverses the flow of the R410A, the service fellow gave it a bit of a tap and restarted unit to find that it would work, hope this help some one else out there with a similar problem, the inside unit operation and timer light would flash together twice then just the operation light would flash five times, was told by Fujitsu that this was the code for refrigerant problem.
Jul 28, 2008 | Fujitsu Heating & Cooling
Fujitsu Heat Pump - problems with timer? When starting the heat pump - the operation light, together with the timer light blinks twice, then the operation light blinks another five times. Then the...
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Jun 24, 2008 | Fujitsu Heating & Cooling
Heating & Cooling Logo
11 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
