Question about Canon S520 InkJet Photo Printer
Canon S 520 doesn`t print
My canon S520 doesn`t print - the yellow lamp is twinkling a few times and than the green lamp one time and it goes like that. I pushed the reset button, but it stillwon't work. I switched the printer off and than on, but the problem stays. What shall I do?
  • 7 more comments
  • Kayles70 Nov 07, 2007
    I have removed a small peice of paper...I cannot see any other paper jams. I have replaced the ink cartridges, turned the printer on & off, re-started computer. The light persists in blinking orange, then green for a second (to taunt me I think!!) then blinking orange again. It will not print. Any suggestions appreciated.
  • Anonymous Dec 27, 2007
    orange light on printer flashes 7 times then the green light flashes 1.
    i can turn the printer off using the pc.
  • Anonymous Feb 29, 2008
    monator says paper jam and to clear paper from outlet. there is no paper jam and al paper is clear. I ve checke over and over for paper and reboo
    ted the machine ..the same massage appears...this started when a page went thru with difficvulty but came thru fuly intact but wrinkeled
  • Anonymous Jul 25, 2008
    amber light blinks 7 tmes and will not print,Removed cartridge and reinstalled but still will not print.
  • moo1995 Oct 07, 2008
    the green light is on. my ink cartrides are new but no print comes out of the paper. i have tried it plenty of times. it used to work on the same laptop so i don't understand why it won't work now that we've moved to a different country. i want to smash the printer already!!!
  • mjchisy Dec 05, 2008
  • Anonymous Jan 28, 2009
    My printer makes a rumbling sound but does nothing, what can I do to repair it or is it done? I love my printer.
  • mattesontim May 20, 2009
    Canon S520 Inkjet printer turns on, goes through initilization, printhead moves back and home OK , service station cycles, paper feed rollers turn, then error light flashes yellow 7 times then once green. Will not print. Any ideas? Thanks, Tim
  • Anonymous Mar 28, 2014
    i try to reset with no result
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Posted on Apr 03, 2009
Waste Ink Tank Full Error Reset
1. Turn off printer
2. Hold down Resume button and press Power button and HOLD Power button.
3. Keep holding down Power button while letting Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button 1 more time.
8. Should be done.
Posted on Feb 01, 2009
    Novelist:
    Scholar:
  • 167 Answers
The printer may be running low on ink. If so replace the ink cartridges. to verify this take the print cartridges out and see if the same condition persists, then put them back.
If it is laser printer try replacing/refilling the toner cartridge.
Also find out whether any software monitoring utility is installed for the printer. In that case you can see the ink/toner levels.
Try reading the manual if you have that all with you, it may be helpful in pinpointig the problem. It may contain troubleshooting information for the particular printer.
Sometimes paper jam will be also indicated like this....If so remove the back cover and find out whether paper or peices of paper is there.
Posted on Oct 19, 2007
SOURCE:
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
Cannot get my canon to respond. Has worked fine in the past. I push to bring online and the light still blinks yellow.
Your machine does a longer green flash and then a series of orange flashes and then green again. I need to know how many orange flashes between the greens to tell you the problem..
Aug 03, 2009 | Canon S520 InkJet Photo Printer
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer is not responding
This is the error light page from the S520. Not sure about this, but probably the same on the S530. 8 Blinks means replace the ink absorber and reset the counter. I think the ink absorber can be gotten at from the bottom, BUT NOT SURE. Try this at your own risk!
7.1 Service Mode Operation
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down the POWER button, let go of the RESUME button before pressing
the RESUME button again twice in succession. Then let go of both RESUME and
POWER buttons.
(At each press of the RESUME button, the indicator toggles between orange and
green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the specified number of
times to execute the desired service function, as listed below.
green.)
Press Indicator Function
0 times Green Power off (Even if there is no print head mounted, the
carriage will return to the home position and lock.)
1 time Orange Service/factory test printout (Including ink sensor check)
2 times Green EEPROM information printout
3 times Orange EEPROM initialization
4 times Green Clears the waste-ink counter (S750/S520)
Waste-ink counter settings (S900/820) (See page 2-34)
5 times Orange Destination (model) setting
After reaching this service function, press the RESUME
button the number of times specified below to set the
destination.
Setting
0 times BJ F900 BJ F890
1 times S900 S820 BJ F700 BJ F500
2 times BJ F890PD S750 S520
3 times S820D
Note: pressing more than 3 times has no effect.
6 times Returns to the function select stage (S750/520)
6~9 times Not used for servicing (S900/820)
More than Green Returns to the function select stage (S900/820)
10 times
4) After selecting a service function, press the POWER button. The green indicator
lights and the service function will be executed. (After each function is executed, the
printer returns to the service function select stage.)
READ THIS CAREFULLY !
Larry
Nov 30, 2008 | Canon S 530D InkJet Printer
Canon S520 blinks 7 times yellow then once green over and over, won't print
Read the info on the link below:
Solutions for flashing lights Issue: Alarm / Power light flashes orange 7 times consecutively (Print head error)
1. Reseat the print head S520 / S750 2. The Print Head may need replacing - S520 3. The S520 may require repair
spacer.gif http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=231&modelid=6611
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | Office Equipment & Supplies
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Canon i455
Seems like your waste ink absorber is full. Try this procedure. It works for a lot of Canon printers.
1. Press and hold the POWER button
2. Turn off the printer by disconnecting the printer power cable,
3. turn on the printer, still holding the POWER button
The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
7. Reconnect the printer cable.
8. And it should be reset.
Jul 18, 2008 | Canon i455 InkJet Photo Printer
Canon s520 problem
I solve mine (4 Yellow Flash + 1 Green) by pushing on the white gear, located at the end right inside, where the cartridges are cleaning. This help the movement of the gear, it was stuck or gem. Do this when you just turning on the printer, then you ear the cycle noise, Your fingers will sense the movement of the gear. Tips: Push the cartridges block to the left to let you enough space to put your hand inside.Now it work normally.
Feb 12, 2008 | Canon S520 InkJet Photo Printer
My canon s520
The user guide for that product says that 7 flashes means the printhead is defective and that you should contact Canon's customer care. If you've recently replaced the print cartridge(s), try putting the old one(s) back in. If the printhead is truly defective, there may be no choice but to contact Canon or replace the printer.
Aug 21, 2007 | Canon S520 InkJet Photo Printer
Canon S520 InkJet Photo Printer Logo
778 people viewed this question
Clive
Clive
old marine
old marine
