Question about Samsung SpinPoint M40 MP0302H (729507523354) Hard Drive
Totally dead. Suspect processor blown - but can't open case despite removing all screws in sight.
Anyone known how to open a Samsung M40 laptop? I've undone every screw in sight but it still seems to be held together at the back. Also suspect I need a new motherboard, but none seem to be available. Shame to throw it away, in perfect condition otherwise and a great PC.
  • 181 Answers
Some computer are funny. sometime like on the acer you remove the panel at the top under the screen first then the keyboard and under the key board more screws before splitting.
Posted on May 29, 2009
How to remove casing
This depends on the laptop. On some laptops the casing is simply clipped together and it is just a case of being careful, others it is a case of the screws are hidden underneath circular suspension pads which are no bigger than a nail head and help to allow airflow underneath the laptop. If this is the case try removing one with a flat head screw driver to see if you find a screw. Other laptops the screws are in plain sight, some laptops are relay annoying though they have no screws and no clips and are literally heat sealed together. You will know if you have a laptop like this because you will not be able to see a thin line the size of the edge of a piece of paper around the side of the laptop. To open a laptop like this use a flat head bit for a soldering iron at 55 degrees c and go around the sides of the laptop were you would expect the line to be and it just opens up.
Caution: Fumes given off from the plastic on laptops are HIGHLY TOXIC always do this when using a high power extractor fan or in open air.
Sep 21, 2013 | Computers & Internet
I am having difficulty opening the case on my HP ze4420us laptop to replace the hard drive with a newer one. The current hard drive states that is failing and advises to move all data to a new hard drive...
flip it over.....in the front right in the middle you should see 2 screws....remove them then grasp the lip and pull the hard drive toward your stomach.......it should slide right out!
Jul 23, 2011 | Computers & Internet
How do i open up the case for a BENQ FP567s LCD monitor to check if the fuse is blown or not? there is no power going through to the LCD....Is there anyone out there that can help tell me how to open up...
Can't say I am familiar with that exact model, but usually there are screws hidden under name plaques and other glued-on paper. Then usually the edges have tabs that "hook" under the opposite edge so even after you get all the screws out you have to insert something to unhook the tabs. But before you do all that, I have not seen many fuses inside a monitor.
Sep 29, 2017 | BenQ FP731 17" LCD Monitor
My nec versa e6300 is shutting off every time im watching a streaming vide from the net, i guess its due to overheating. i think it needs cleaning at the cpu fan but i cant open the casing despite having...
im having this same problem, its also happens when im playing new games such as dead rising 2, 007 Bloodstone, Prince Of Persia 4 etc.. if anyone knows where to find a manual or instructions for step by step dis-assembly, can they email it to me please? juggaluggaroney@hotmail.com
Nov 03, 2010 | NEC Versa FX Notebook
DISSAMBLING SAMSUNG R40 Hello there, SAMSUNG R40 I got the same problem. I don't know how to dissamble my SAMSUNG R40, and the cooler seems to be clogged with dust, so I'm afraid I'll fry my laptop. I've...
If you are not sure what you are doing, it would be a lot better if you put it back together and called a pro to clean it for you, at least it will work when you get it back.
Jun 24, 2009 | Computers & Internet
How do i completely remove the back cover?
If I were you, I would first try a system recovery as it has crashed.
What's an inverter? Does it mean you have connected the power supply with wrong polarity? I dont think you need to open it.
Mar 10, 2009 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
How do you open the moniter ??
with a screw driver pree the openings on the top while you pull the cabinet.
Sep 15, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Open cover of Samsung Samtron monitor
remove two screws on lowerback of the monitor. Loosen the case at the botton and on the top. Two holes will appear on the top. With thin screwdriver push down inserting the screwdriver into this notch.This will release the case. Tks
Oct 30, 2007 | SAMTRON 55V 15" CRT Monitor
CD Drive replacement - Samsung X05
on that model check to see if the any screws under were the drive is. remove them. also i believe the are small latches the hold the keyboard in place. using a flat head screwdriver you should be able to slowly anchor the keyboard out. the drive is underneath and there you go.
Oct 29, 2007 | Samsung X05 Notebook
thake out the screws on the bottom of the lap top then there are 3 very small clips holding in the keyboardone at the control key one at the space bar and one at the down arrow key push thes back and lift out the keyboard it has a cable conector on it so be carefull then you will see two screws holding in the cd drive and a ribbon conector remove it by pushing forward the small ribbon holder then remove the drive
Computers & Internet Logo
124 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
