Question about Zapf Baby born 778166
Left arm was pulled off and clip is broken - Zapf Baby born 778166
Passenger front door will not unlock and will not open from inside or outside
Id say the clip that holds to the latch has broken pull ur trim off and have alook if this has happened it should be a small white clip attached to an arm
Oct 02, 2016 | Cars & Trucks
I need to have 'step-by-step' instructions for replacing the driver side windshield wiper arm on my 2000 Ford Explorer. Can you help me with this?
  • Turn your wipers off, using the stalk on the left side of your steering column. Turn your ignition off and remove the key.
  • 2
    Pull the wiper blade up to lift it to the service position. Pull the front part of the blade down to position it at an angle.
  • 3
    Pull back the lock pin on the center part of the wiper blade (where it connects to the wiper arm). This unlocks the blade from the wiper arm.
  • 4
    Grasp the blade on each side and pull it down (away from the extended wiper arm) to release it from the "U" clip.
  • 5
    Repeat the process for the other wiper blade, if desired. Removing the driver's side and passenger's side wiper blade is the same.
  • 6
    Install the new wiper blade. Open the lock pin on the new blade, and then insert it into the wiper arm "U" clip. Close the lock pin and lower the wiper blade to its normal position.
  • Jan 29, 2011 | Ford Explorer Cars & Trucks
    Upper spray arm falls off during operation, even after snapping
    the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
    Feb 04, 2010 | Frigidaire Professional Series 24 in....
    The wiper motor on my 1983 Ford Ranger still works but the wipers no longer move. I think there is a failure of the mechanical linkage. Where do I go to find repair parts?
    why do you think the motor still works if the wipers don't move? Can you hear the motor run or can you see a little movement when you turn the switch on?
    What happens when you activate the washers?
    go to a salvage yard that allows you to remove the parts yourself. Then you can see how the motor and linkage assembly comes out.
    don't have 1983 info, but here is 1994:
    Section 01-16A: Wiper and Washer System, Ranger/Explorer 1994 Ranger and Explorer Vehicles Workshop Manual
    DESCRIPTION AND OPERATION Windshield Wiper System, Ranger/Explorer The windshield wipers are actuated by a permanent magnet, rotary-type electric windshield wiper motor (17504) . The two windshield wiper pivot arms (17526) and windshield wiper blades (17528) are mounted on a pivot shaft, one at each side of the windshield. The windshield wiper mounting arm and pivot shaft (17566) are connected to the motor by windshield wiper adapter and connecting arm clip (17531) . Ranger and Explorer vehicles are equipped with an interval wiper and washer (IWW) system featuring a lever-type turn signal and windshield wiper switch (13K359) mounted on the steering column. The IWW windshield wiper governor (17C476) uses a relay contact to control current to the windshield wiper motor . The governor electronic circuitry controls the contact to supply current to windshield wiper motor . A rear wiper/washer system is available on Explorer vehicles. The rear window wiper system consists of a windshield wiper motor mounted inside the liftgate (40010) , an articulating windshield wiper pivot arm and windshield wiper blade , a windshield wiper/washer switch (17A553) and an inline circuit breaker. The front electric windshield washer system consists of a control switch, integral with the turn signal, a windshield washer reservoir (17618) and windshield wiper motor and the necessary windshield washer hoses (17A605) , windshield washer nozzle jet and brackets (17603) and attaching parts.
    Pivot Shafts and Linkage Removal and Installation
    NOTE: The left and right pivot and windshield wiper adapter and connecting arm clip assemblies are serviced separately.
    1. Perform Steps 1 through 9 of Windshield Wiper Motor Removal as described in this section.
    1. If servicing left windshield wiper adapter and connecting arm clip , remove left windshield wiper mounting arm and pivot shaft and windshield wiper blade assembly.
    1. Remove left windshield wiper adapter and connecting arm clip access cover.
    1. Remove left pivot nut, lower windshield wiper adapter and connecting arm clip and slide it out through left access opening. For installation, follow removal procedures in reverse order. Tighten nut to 10-13 Nm (7-10 ft-lb). Make sure the clip is fully seated in the windshield wiper adapter and connecting arm clip . Do not try to install clip with windshield wiper adapter and connecting arm clip on motor crank pin.
    Windshield Wiper Motor Windshield wiper motor are not serviceable. If worn or damaged, the windshield wiper motor must be replaced as an assembly. Removal
    1. Cycle windshield wiper blades until in straight-up position and turn ignition switch OFF.
    1. Disconnect battery and wiper motor electrical connector.
    1. Remove the right windshield wiper mounting arm and pivot shaft and windshield wiper blade .
    1. Disconnect the battery ground cable (14301).
    1. Remove the right pivot nut and allow the windshield wiper adapter and connecting arm clip to drop into the cowl top outer panel .
    1. Remove the linkage access cover, located on the right side of the dash panel near the windshield wiper motor.
    1. Reach through the access cover opening and unsnap the wiper motor clip.
    1. Push the clip away from the windshield wiper adapter and connecting arm clip until it clears the nib on the crack pin. Then, push the clip off the windshield wiper adapter and connecting arm clip.
    1. Remove the windshield wiper adapter and connecting arm clip from windshield wiper motor crank pin.
    1. Remove nut and ground strap.
    1. Remove three attaching nuts from windshield wiper motor. Remove the windshield wiper motor .
    Installation
    1. Position the windshield wiper motor and install the three attaching screws. Tighten to 13.6-19.0 Nm (10-14 ft-lb).
    1. Install nut and ground strap.
    1. Connect wiper motor electrical connector.
    1. Install clip completely onto right windshield wiper adapter and connecting arm clip. Make sure the clip is fully seated. Do not put the windshield wiper adapter and connecting arm clip on the motor crank pin and then try to install the clip.
    1. Install the left windshield wiper adapter and connecting arm clip onto the wiper motor crank pin.
    1. Install the right windshield wiper adapter and connecting arm clip onto the wiper motor crank pin. Pull the windshield wiper adapter and connecting arm clip onto the crank pin until it snaps into place. The clip is properly installed if the nib is protruding through the center of the clip.
    1. Install the right windshield wiper mounting arm and pivot shaft and nut. Tighten the nut to 9.5-12.5 Nm (84-110 in-lb). NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
    1. Connect the battery ground cable and turn the ignition switch on. Turn turn signal and windshield wiper switch off so windshield wiper motor will park, then turn ignition switch off. Replace right windshield wiper adapter and connecting arm clip access cover.
    1. Install the windshield wiper mounting arm and pivot shaft and windshield wiper blade assemblies on the pivot shafts to dimension X. Dimension X is the distance between the centerline of the blade saddle and the top edge of the cowl top outer panel grille. The value of Dimension X for each vehicle is given in the Dimension X chart in the Specifications portion of this section.
    1. Test the system.
    Jan 04, 2010 | 1983 Ford Ranger
    2005 tahoe wiper replacement
    My tahoe has a plastic piece just to the left of the metal attaching arm. It is easiest to see on the driver side wiper. There is just enough room to slip a flat blade screw driver into and then pop upwards. After this clip is popped, slowly move the wiper blade to the right as you pull that clip further upward. The blade can now be removed. Of course if you have a different type blade this will not work.
    Dec 14, 2009 | 2006 Chevrolet Tahoe
    Top arm on my Maytag MDB5600AWW keeps falling off
    Sounds like the retainer clip for top arm is defective. Replace the following parts:
    1: 99002676 Washer Arm
    2: 99002753 Top Washer Arm Retainer
    To replace unclip top manifold from rear top clip on back wall then pull down on top retainer clip and remove arm, replace in reverse of these instructions.
    Part can be ordered off net or thru any appliance parts house.
    Nov 12, 2009 | Dishwashers
    Left door
    don't know about your trunk...
    but for the passenger door, it sounds like the linkage connecting to the outer handle is broken...on the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge.
    Sep 12, 2009 | 2002 Jaguar X-Type
    My daughters chevy cavilier's driver side door has fallen and will not roll up. how can that be fixed?
    you'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. Then pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything. It's most likely the arm is broken or the gears have slipped
    Aug 12, 2009 | 2004 Chevrolet Cavalier
    Ge wpsq3120t2ww I have a broken control knob, how do i replace this?
    Knob(s) on left side of machine just pull off. Make sure the metal D clip comes off too. Push new knob on.
    Timer knob: Pull knob out and remove nylon clip off back side of knob. (use a thin screwdriver to push it off, or a thin needle nose plier to pull if off) then knob pulls off easy. Push new knob on with clip already in place. Easy.
    Jul 08, 2009 | GE Profile WPSR3120WWW
    Spray arms clogged
    Top: Remove the upper tray by releasing the clips on the ends of the runners. (Squeeze the top of the clip and pull upwards). Remove the spray arm by holding the round plastic clip that holds the arm and turning the arm. It will unscrew.
    Bottom: Grab spray arm in centre and pull sharply upwards to unclip.
    Wash in warm water and solvent-free detergent.
    Jun 11, 2009 | Samsung Dishwashers
    Zapf Baby born 778166 Logo
    104 people viewed this question
    Top Zapf Baby Gear Experts
    Dorel UK
    Dorel UK
    JonSnell Electronic
    JonSnell Electronic
    Are you a Zapf Baby Gear Expert? Answer questions, earn points and help others
