Kchibo radio kk d202 - Office Equipment & Supplies
How do I get the Autocue function to work on the Technics SL-D202 direct drive turntable?
When you say that the auto cue does not function properly,do you mean that the arm will not lift from the rest onto the record or do you mean that the set down point of the arm on the record is not correct? Or does it not work at all?
Jun 29, 2014 | Technics Audio Players & Recorders
Oil capacity for a devilbiss cac-4029 pump
The sears manual that has that pump in it lists the oil capacity as 16 oz. of 30 wt non-detergent oil. If you need parts, many are still available under other manufacturers like porter cable. Several parts are only available in kits. Ring kit KK-4313, Reed valves KK-4275, Gaskets KK-4312-2, valve kit KK-4315.
http://www.devilbissparts.com/OilLubeStat%20PDF%20files/cac-4029.pdf
http://www.mastertoolrepair.com/air-compressor-pump-parts-cac-4029-p-24953.html
Jan 09, 2012 | Computers & Internet
Turns on but turns off and will not play
This can happen if the speaker wires are shorted.
Nov 16, 2009 | JVC RX-D202 Receiver
I have stiletto 10 will not charge when plugged in
Did you try the back ,off radio slot too.Also check contacts andturn it off anlet it come on,let it charge with opening (dog and stars),Good Luck. union kk
Feb 21, 2009 | Sirius STILETTO 100 MP3 Player
I know you would charge a fee, but would you have access to a radio unlock code for a Chrysler 1999 Jeep Cherokee Sport if VIN # provided?
okay you need to go to radio code .com thats radiocode.com they might charge you but you will need the vin num make and model kk
Jan 29, 2009 | Car Audio & Video
66 people viewed this question
k24674
jasbo
jasbo
