Question about Kelty Tents: Acadia 4 Tent
Lost my acadia 4 tent poles - Kelty Tents: Acadia 4 Tent
    Novelist:
  • 269 Answers
Might be expensive or impossible but you can try Kelty directly.
1-866-349-7225.
In Canada, email: Canadacustomerservice@Americanrec.com or call 1-866-349-7225 x 3726
Corporate Headquarters:
6235 Lookout Road
Boulder, CO 80301
PH: 800-535-3589 (M-F 8am - 4pm MST)
Posted on Aug 02, 2015
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
May 31, 2015 | Northwest Territory Sierra Dome Backpack...
I need replacement poles for old model melty tents
It is likely to be difficult to impossible. Expect that it might be fairly expensive. Contact Kelty at:
1-866-349-7225.
Apr 13, 2014 | Kelty Pagoda 4 Tent
Kelty tent pagosa 4 pole split
You can call Kelty at 1-866-349-7225.
Feb 24, 2013 | Kelty Pagosa 4 Tent
Can't get pole into the fly tabs
Get tough.. Your assembled pole will bend.. and it will bend a lot, as long as it isn't kinked in one spot. You can do it...
Jan 16, 2013 | Kelty Acadia 4 3-Season Camping Tent
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    I have a disney princess tent that goes over a twin bed and i lost the instructions to putting it together and i need help.
  • 1
    Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space.
  • 2
    Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules.
  • 3
    Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body.
  • 4
    Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
  • Apr 22, 2011 | Toys
    I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
    I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
    Paul.
    Dec 23, 2010 | Sport & Outdoor - Others
    Lost instructions for building 6 man white stag tent how do poles go up
    I have a second hand white stag tent whith the tent # 28242 white stag six man tent. I need set up instructions and my be missing some pole for set up
    Sep 01, 2010 | Rock & Ice Climbing
    Square tent with 2 types gazebo poles, varenda, 2 side windows
    the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
    shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
    May 04, 2010 | Wenzel 18'x10' Sycamore 3 Room Tent
    Tent
    Well, you should have Three (3) longer poles and Two (2) shorter. Two (2) of the longer poles will be the basic construction poles. They will basically make an "X" across the top of the tent making the four courners of the tent. The other longer pole with also go across the top of the tent and right through the "X" made by the other two (2). This will push out the sides and make is "dome-like".
    The two (2) shorter poles will go on either side of the enterance. These will hold up the sides of the tent to give you more volume space on the inside. Not exactly nessasary but if you want more than one or two people to fit inside, you'll need these.
    Hope I helped.
    Oct 14, 2008 | Sport & Outdoor - Others
    Kelty Tents: Acadia 4 Tent Logo
    365 people viewed this question
    Top Kelty Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Kelty Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
